Question about Dynex 30-Pin Dock Adapter for Apple iPod shuffle
Cant' get it to work in car 30pin cable
I bought the Dynex 30 pin dock adapter for my new shuffle, when I connect to my new car install for the ipod (just a 30 pin cable it connects to) it shows that it's "reading" and then I get "error." I made sure the button is switched to speaker and my shuffle is set to "on" and tried every button combination but can't get my car to read and play the music on it. Otherwise, my shuffle works fine w/o it. Please advise.
  • Anonymous Mar 20, 2009
    I bought the adapter and pluged into the 30pin wire from my cd player deck, and then plugged the shuffle into it, with the shuffle on and switched to the speaker mode, and my deck says error . Why?
5 Suggested Answers
SOURCE: Can I cahrge my Samsung mp3 player using my ipod shuffle docking station
the device will turn on and it will say baterry charging. after that it will say charge complete. if this does not work you may only be able to use the actual computer through the usb
Posted on Jul 31, 2007
SOURCE: Dynex iPod Dock with Remote
i had the same problem. it seems that you have to use the remote to turn the volume up on the ipod instead of doing it manually. that worked for me.
Posted on Sep 13, 2008
SOURCE: What does the little electrical bolt symbol mean?
this is obviously a power or connectivity issue, check that the device ( your ipod ) is correctly seated into the logitech speaker system, and check the power cables are connected according to the manual which came with the logitech speaker system.
question u may ask yourself? - does the ipod work as it should on its own? (without non-apple devices/components attached to it) - if it doesnt - take to an apple store or call or seek apple support.
it sounds like your ipod is low on power from source.
i hope this directs you in the right direction, party on!
Posted on Dec 01, 2008
  • 413 Answers
SOURCE: ipod shuffle 2nd generation is not responding
Have a look here at the Apple website
http://www.apple.com/support/ipod/five_rs/shuffle2gen/
Posted on May 29, 2009
  • 87 Answers
SOURCE: ipod shuffle 2nd gen problem
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
Retry with a different USB port if you cannot see iPod shuffle in iTunes.
Restart your computer, and make sure you have the latest software updates
installed.
 Reinstall iTunes software from the latest version on the web.
 If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
 Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
Turn iPod shuffle off, wait five seconds, and then turn it on again.
You may need to restore iPod shuffle software
Posted on May 31, 2009
I own an iPod (30 pin port) and am trying to find a 30pin to lightning adaptor to be able to connect it to a new ihome sound system with a lightning port. Any suggestions?
I buy all of my cell accessories/adapters like this on ebay. They're usually very cheap and ship directly from China. I've gotten some that don't work, but they usually send a replacement.
They're almost always under $5 including shipping.
http://www.ebay.com/itm/30-Pin-Docking-Male-to-8-Pin-Female-Data-Adapter-For-iPhone-4-4S-i-Pad-2-3-HY-/271661582355?pt=US_Cell_Phone_PDA_Cables_Adapters&hash=item3f404ac813
Dec 25, 2014 | Audio Players & Recorders
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
I have a new docking stationbut am unable to connect it to my old apple ipod canyou help please
Probably your new docking station is equipped with the new Lightning connector used by iPhones and iPads instead of the 30-pin connector used by old and newer iPods. Search on Internet to see if you can find a Lightning-to-30-pin adapter. Do not get a 30-pin-to-Lightning adapter; you will waste your money.The latter adapter is more readily available, but is used to connect an iPhone or iPad to and OLDER docking station equipped with a 30-pin connector.
Dec 25, 2014 | Apple Audio Players & Recorders
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
Will not charge a ipod touch 2
If you're willing to spend $40, there's an adapter available from Scosche Accessories. It comes in both black and white and they say it will convert any docking device to the new charging format. (The problem is that Apple has discontinued charging via the FireWire pin - which virtually all accessories - even including Bose - have used up to now. All the 2nd Generation stuff now uses direct USB charging, not FireWire.
Check out the convertor at:
http://scosche.com/products/sfID1/210/sfID2/339/sfID3/318/productID/1694
Dave
Dec 29, 2008 | JBL On Stage II with Remote Remote Control...
Getting error message software not compatible with IPod
This compatibility issue is caused by the same change with the Apple Dock Connecter introduced with the iPhone 3G. Inside the iPod / iPhone Dock Connecter are 30 metal pins. Previous iPods and iPhones allowed for charging either over pins reserved for the USB connection or pins reserved for the obsolete Firewire connection.
While Apple apparently announced this upcoming change to manufactures of “Made for iPod” accessories back in 2005, Apple only formerly discontinued Firewire charging support with the most recent iPods. New iPods and iPhones can only charge via the USB pin.
As such, there is no way that a software update can fix this issue in the future; this is truly a modification in iPod hardware.
Dec 22, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
Nov 30, 2008 | Dynex 30-Pin Dock Adapter for Apple iPod...
Need a dock
Greetings ronvibb,
Your in luck! (I almost thought this couldn't be done with a shuffle) There is an adapter that should allow you to connect your shuffle with the standard Yamaha ipod accessory. The adapter can be found at:
http://www.bestbuy.com/site/olspage.jsp?skuId=8525287&st=ipod+shuffle+docking+stations&lp=7&type=product&cp=1&id=1186007813594
Enjoy the music.
Jon
Go Ahead. Use Us.
Jun 22, 2008 | Audio Players & Recorders
Itunes and ipod are not cooperating with me.
I bought an Ipod shuffle 2nd generation yesterday, it charged all night and orange light was still blinking. Tried listening to songs and sometimes it would play but most times wouldn't. Took it back for exchange and same problem. Then I realized the problem is not with the USB plug or computer reoconizing ipod but in the docking itself. I applied pressure on the top side of docked Ipod and bottom of docking station and the computer recognized the Ipod. Release pressure and lose connection. The problem is that the docking station and earbuds do not connect with ipod and the fixes provided by apple doesn't address or fix this problem.
Oct 30, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Dynex 30-Pin Dock Adapter for Apple iPod shuffle Logo
Top Dynex Audio Players & Recorders Experts
Mike Neath
Mike Neath
Electro Med Services...
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
