HP 3600n error 59.90? - Office Equipment & Supplies
5 Suggested Answers
  • 159 Answers
SOURCE: HP 3600N Printer 10.10.01 error
The printer cannot read or write to at least one
print cartridge memory tag, or at least one
memory tag is missing.
1. Open the front door.
2. Remove the print cartridges,
reinstall them.
3. Close the front door.
4. Turn the printer off and then on.
Posted on Mar 30, 2008
Replece the cartridge Cyan...
Posted on Apr 27, 2010
  • 10 Answers
SOURCE: LaserJet 3600n Printer: how can i fix 59.C0 printer error hp lj 3600...
i have many times working on this printer and i always experience this problem...i think this problem is disalignment of the main gear...check the gear if its on the alignment and its work for me and the problem never comes back
Posted on Oct 19, 2010
  • 1121 Answers
SOURCE: PCL XL error on HP color laserjet 3600n
Verify printer functionalityTo verify printer functionality, use the following steps:
  1. Turn off the printer and then unplug the Parallel, Serial, or Network data cable from the back of the printer. This will ensure that the information is not being received from the computer or network.
  2. Turn on the printer and verify that the word Ready appears on the printer display.
  3. Print a self-test on the printer by performing the following steps:
    1. Go to the on the printer.
    2. Press the MENU key until INFORMATION MENU appears on the printer display.
    3. Press the Item key until PRINT MENU MAP appears on the printer display.
    4. Press the SELECT button. The printer should generate a print job.
Try to print a page using the software application or a document in question after attempting each item of the following workaround. This will help determine if the changes made have caused the desired results to occur.
  1. Connect the printer directly to the computer. Use an IEEE/1284-compliant cable.
  2. Print a Test Page by completing the following steps:
    1. Click Start and then Settings and Printers .
    2. Right-click the appropriate printer driver.
    3. Select Properties .
    4. Click the General tab and click the button in the lower right-hand corner that is labeledPrint Test Page .
If the error is not resolved, try a different IEEE 1284-compliant cable. If there is no possibility to direct connect, use a different network cable, or network port, on the hub. Simplify communication options depending on the specific printer. Use the Control Panel on the printer to turn off High Speed andAdvanced Functions . To turn off High Speed and Advanced Functions complete the following steps:
  1. Press the MENU key.
  3. Press I/O MENU and disable Parallel High Speed .
  4. Press I/O MENU and disable Advanced Functions .
  5. Connect the printer to a different location, change parallel/USB/network cables. Bypass switch/hub (if there is any).
For problems with certain applications or documents, try modifying the HP LaserJet printer series PCL6 driver settings, such as:
  • Use lower resolution, such as 600 dpi.
  • Enable or disable Send True Type as Bitmaps .
  • Disable the Print Optimization under Printer Properties => Advanced => Document Option .
Some more steps:
  • Try changing the personality type to Auto/PCL/PS in printer Control Panel.
  • If changing personality does not make any difference, remove the current driver completely (from Server Properties ), restart the system, and install PostScript (PS) driver.
  • While installing the printer driver, select the standard TCP/IP port if the default is HP Port , and vice-versa.
General troubleshooting tipsContinue to isolate the error by printing the job in question after applying each of the following suggestions:
  1. Remove any additional memory that has been added to the printer after being purchased. Refer to the User's Manual that was supplied with the printer for memory removal instructions.
  2. Try using a different Font within the application or document in question.
  3. Try to print using the PCL5e driver that came with the HP LaserJet Printing System.
Posted on Dec 21, 2011
I have an HP Color Laserjet 3600n with error 10.10.03
Thank you for contacting FixYa with your printer issue. Support Document (110993)
10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
  1. Open and close the front door.
  2. Remove the print cartridges, and then reinstall them.
  5. If the error persists, contact HP Support.
Helpful CLJ 3600 Error Message Tables:
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 22, 2011 | HP LaserJet 3600n Printer
Error code 51.23 on HP 3600n printer
Try replacing Laser/Scanner Unit. LSU's ARE replaceble. You just have to remove too many screws.
Jun 02, 2010 | HP LaserJet 3600n Printer
My Hp laserjet 3600n printer gives error code 59.63
59.53 ERROR
59.63 ERROR
An error occurred with the yellow printcartridge
drive motor during startup or
A problem with the Yellow Print cart. If you changed it recently try changing it again. If not the cart. then the unit may need a motor or board.
Jan 12, 2009 | HP LaserJet 3600n Printer
1,095 people viewed this question
