Question about Cameras
My husband has a Canon DS6014. I would like the screen on the back of the camera to show what the lens is looking at as I am taking pictures (as opposed to looking through the viewfinder). Right now, the screen remains dark unless I am reviewing pictures, or am in the menu. I've looked through the menu options and cant seem to find way to make it happen. Can you help?
4 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Posted on Feb 11, 2008
  • 155 Answers
SOURCE: Nikon D700 viewfinder dark
It sounds as if there is a problem with aperture blades not fully opening.
A quick test...
With a known good lens on the camera, set it to shutter priority mode. Point the camera at a plain wall or ceiling, half press the shutter button and note the aperture reading suggested by the camera. (Play around with the shutter speed settings until you get something around about f11.)
If possible, switch to another good lens and do the same. (You will need to point the camera at the same wall or ceiling!) You should find that without altering any settings, you will get the same, or very similar, aperture reading as before.
Now try the suspect lens. If there is a a fault with the aperture, the camera will almost certainly suggest that a significantly different aperture setting is required.
Hope this helps!
Posted on Jun 20, 2009
  • 164 Answers
SOURCE: dark viewfinder
Reset the camera to factory settings.
If still you have the problem, use a different se of lens.
It seems the iris is not working properly in the lens.
Try in clean the lens and the camera contacts too.
Best regards,
Posted on Jul 23, 2009
Canon g11 telephoto lens vignette
You have to zoom the camera lens out for that lens to work.
Feb 15, 2014 | Opteka 32x HD?² Telephoto Lens for Canon...
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Black Screen
But does it take usefull pictures? I mean, after you take the picture, can you download it onto the computer?
  • If yes, you probably deactivated the back LCD by mistake. Look for a "display" button (or similar) and push it. It will cycle through all of the available display modes.
  • If not, it's probably a software error. Take the camera to a local electronist or Canon dealer for repairs.
Apr 09, 2010 | Canon PowerShot A540 Digital Camera
Black screen on canon a 550
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on or off to save batteries. You would then use the optical viewfinder, just like you've been doing. To turn the screen back on, press the button once more.
Oct 11, 2009 | Canon PowerShot A550 Digital Camera
NO IMAGE ON THE DISPLAY, HOW DO I CHANGE BACK FROM THE LENS TO TH
Do you really mean won't take a picture, or are the pictures that it's taking black like the LCD screen? Download some of the pictures to your computer and check. If the camera's taking black pictures, see the following two links:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Jun 22, 2009 | Canon PowerShot S230 / IXUS 179 Digital...
Black screen on Canon S1 IS camera
If Canon S1 IS does not show picture in camera mode and show memory card stored pictures in playback then its CCD Imgaer problem and ccd imager will be replaced.
Canon will repair it free of cost, click Canon CCD Imager Advisory for details.
Jun 11, 2009 | Canon PowerShot S1 IS Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
My camera display screen is only showing weird colors but works when I take pictures
A loose connection perhaps
A gentle taspe may restore it - or it may not.
Canon support will advise on your next move
Sep 14, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it fixable?
Thanks for that link, I will keep it handy! Be careful however, because the exact same symptom can be caused by a stuck shutter. To tell if it is a stuck shutter follow these steps: 1. Turn off the flash!! 2. Look down into the lens. 3. Take a picture. Did you see anything change? The opening at the center should be momentarily covered by a matte black shield. If you take a picture and see no change inside the lens then the shutter is stuck closed or open. If Canon finds your shutter to be stuck and not a CCD failure, the repair will not be free.. very not free. David Millier Advance Camera Repair
Mar 10, 2007 | Canon PowerShot A70 Digital Camera
Cameras Logo
53 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
