Question about Garmin StreetPilot c510 Deluxe GPS Receiver
Need Help Hi. My Gps is constantly plugged in, its plugged in the cigarette lighter. I used it, got back in the car and it did not want to come on. Even if I try to put it on via the power button it does not come on. Any advice??
  • HenkTidy Jul 16, 2008
Mine did this, i just plulled it apart, disconnected the battery, waited 10 seconds and plugged it back in. Works fine now.
Posted on Sep 09, 2008
  • 31 Answers
This has happened to me, I had the StreePilot C490, the internal battery got overheated from keeping it plugged in. If you get a new Battery for it, it will be all set.
If this helps at all, please rate this a FixYa. - Evolution
Posted on Jul 16, 2008
Cigarette lighter socket came out, no charging
You probably pulled the wiring plug off the back of the socket. Or the fuse went when the socket came out.
Mar 05, 2014 | 2002 Toyota Camry
Cigarette lighter keeps blowing fuse
when the lighter is not pushed in does the fuse still blow? If not get a new plug in bit. Try some other plug in unit (GPS--dash cam--tyre compressor) or anything that uses a plug for the cigarette lighter and see it the fuse still blows.
Dec 07, 2013 | 2007 Kia Optima
No light on vehicle power cable
If this is a cigarette lighter plug, the fuse may be blown. Unscrew the top where it plugs into the cigarette lighter and check the fuse. But, more than likely the fuse in your car for the cigarette lighter is blown. Check the car fuse first.
Aug 18, 2012 | Garmin nuvi 1490T GPS Receiver
Hello. I have a problem that no one has seemed to be able to help me with. All i get is a dumbfounded look or scratch on the head. I have a Garmin Nuvi 780 GPS for the car. I do not have a cigarette...
Hi JoAnn, What you really need is a cigarette lighter socket in your car and this doesn't have to be a big problem. In most car accessory shops you can get cigarette lighter socket splitters, like the one at
Now I know these are supposed to plug into your cigarette lighter socket but you can remove the plug from the end of it and get wired directly to the fuse board of your car. The wire that goes to the centre tip of the plug connects to the positive/fuse of the fuse board and the wire that's connected to the outer part of the plug connects directly to an unpainted metal part of the car. You can do this by loosening a bolt, wrapping the wire around it and tightening it again. The block with the sockets on it can be either glued with double sided tape to a convenient part of your car interior or left loose if you prefer.
If you're not happy wiring it directly yourself it should not cost a lot to get done in a garage. If I was in your position that's what I'd do.
Mar 28, 2011 | Garmin Nuvi 780 4.4 in. Car GPS Receiver
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
Porsche cigarette lighter is bigger than standard cigarette plug
Found a cigarette lighter assembly that is the standard DIN/SAE size that is a direct replacement for the one in my car.
Aug 31, 2009 | Garmin zumo 550 GPS Receiver
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Mar 01, 2009 | Tomtom One XL GPS Receiver
Most GPS would have a cigarette lighter adapter to charge the unit while in the car. If you vehicle has onle 1, then it would be needed to pullout the cigarette lighter and use that for the charger. If your unit does not have a cigarette lighter adapter/charger, then pls post back the brand/model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Garmin GPS
Will not turn on
do you plug it into the cigarette lighter or is it installed (wired) behind the cigarette lighter. If so and you happen to plug something into the lighter you run the risk of shorting out our friend TomTom (I did it twice)
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Garmin StreetPilot  c510 Deluxe GPS Receiver Logo
95 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
