Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Samsung series 550 1080 hdtv power problem
The hdtv won't turn on. if i press the power button with the remote the red light just blinks, but no sound or any other reaction.
what should i do?
Is the TV main switch turned on?
There might be a main power switch on the TV somewhere.
Posted on Jul 28, 2008
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
Mar 02, 2013 | Samsung Televison & Video
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Kdf-60xs955 red continous blinking lamp light
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Jerry Greenberg
Jerry Greenberg
