Question about Samsung DLP HL-P5663W 56" TV
Red light stays on with TV remote
Same problem as you describe, changing batteries and resetting doesn't work. Did you ever get an answer to your query?
    Sergeant:
    Champion:
  • 375 Answers
Do you have your owners manual if so look up remote operation and manual tv operation
Posted on Jul 30, 2008
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
My TV remote doesn't work. I changed the batteries but that didn't solve the problem.
The remote can be tested and Radio Shack and most repair shops have a simple card for testing---point the remote at the card and press buttons and the strip on the card either lights up or not.
Depending on the problem most remotes are fixable.
Stay away from "Universals" as they are usually trouble.
If batteries and remote test good the set has a receiver for the infrared signal the remote sends-
95% of the time it is the remote and not the receiver or set.
A precise model number would tell me of common issues with your set including the remote.
Mar 14, 2012 | Televison & Video
No power to my DP 19649 Sanyo TV. Where is reset button? Manual doesn't mention one.
There is no reset button
The hard reset process is to disconnect power for 1 hour then reconnect
Feb 19, 2012 | Televison & Video
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
Wont power up, blue lights stay on have changed out the batteries
try resetting the remote and the console. in the console you open front panel and their is a red reset button press this firmly then remove batteries from back of remote press the reset on the console again. Then replace the batteries press the red reset on the console a third time and then push the red reset button on the back of the wii remote this should take care jof your problem.
Nov 14, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
I have a mitsubishi dlp tv model 52525 and I just changed the lamp and the lamp light still comes on and stays red. lamp comes on for about 5 seconds and quits. is there a code on the remote to hard...
these set have a known problem with some blown capacitors in the power supply from the syptoms you describe this could be the issue. i know of no reset command that would help
Oct 07, 2008 | Mitsubishi Televison & Video
Remote control (UBRC-120) will not work the unit.
I had the same problem. resolved it by the following......
1. Press and hold the TV button until the red LED turns on and stays on.
2. enter 00000, the red LED will flash and turn off
3. test remote
This procedure should put the remote settings in default for TV.
if all goes well remote should operate the TV
Oct 05, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Samsung DLP HL-P5663W 56" TV Logo
Jerry Greenberg
Jerry Greenberg
