Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel The light is on indicating the control panel is locked. How do I get it to unlock?
Press and hold the end of cycle signal button for three seconds. this will unlock the control panel. you can do the same if you would like to lock it
Posted on Jul 19, 2008
How do you unlock a whirpool duet control panel?
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Washing Machines
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    The controls locked is displayed. what causes this and how do i get the controls unlocked.
    Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
    My Kenmore washer has a "control locked" light on and I can't unlock it. How do I disable this function?
    The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This feature can often be set unintentionally and usually is not an indication of an actual problem with the appliance.
    With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
    If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
    http://www.fixya.com/support/r3608801-control_panel_lock
    These instructions are also printed on the front panel of the appliance and in the owner's manual.
    If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
    Jun 28, 2010 | Washing Machines
    On My Whirlpool Duet Model# GHW9150PW A setting kicked on that
    May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Control panel locked,how to unlock
    The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
    If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
    If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue).
    Please post back if you still need assistance. I hope this helps you.
    Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Control locked light stays on after load is finished.
    The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
    If this is a Whirlpool Duet, the following link explains how to lock/unlock this feature:
    These instructions are printed on the front panel of the appliance and in the owner's manual.
    If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please let me know. I hope this corrects the problem for you.
    Mar 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    23 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
