Today my firewire bus powered mac mini 320GB external hard drive (that i bought this year) stopped being powered by firewire alone and needed the USB plugging in as well to be recognised and used...the icon shows it as a firewire drive with both plugged in. 2.4GHz (Penryn) Macbook Pro/320GB mac mini
    Genius:
  • 1,447 Answers
Hi-
Chances are these large memory hard drive should be plugin with a USB and adapter of its own since 320Gb is too big and needs power to be able to recognize. But if you find it defective you have a year warranty from the manufacturer, you can call them up for a replacement.
Hope this help. Thanks for using Fixya!
Posted on Jul 16, 2008
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Mac cannot see 750GB maxtor 4
Did you disconnect the firewire drive before installing? You may need to update your firmware. Also, try these things:
1. Shut down and disconnect your firewire drive leaving nothing is connected to the firewire ports.
2. Restart, and use Disk Utility to repair permissions on your internal.
3. Shut down, and disconnect the AC power from the computer and your drive; also remove battery if laptop.
4. Let computer sit unpowered and disconnected for15 minutes.
5. Reconnect AC power to only the computer and reinsert battery.
6. Restart computer.
7. Verify that firewire ports are visible using System Profiler.
8. Reconnect your firewire drive, and refresh window in System Profiler to rescan the firewire bus, and confirm that drive is visible.
9. Repair disk and permissions on the firewire drive.
Dec 13, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
How to Connect Maxtor OneTouch 4 Mini 320Gb to PC
I have one as well running along with a PC. PCs and Macs are formatted differently. Go to www.maxtor.com and create a search for reformatting from a Mac to a PC with your Operating System in the search as well. Should have no problems after doing that. It will tell you and or show you where and how to reformat.
Oct 01, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
Simpletech Signature Mini not reading
It is easy, just conect it to the motherboard as a slave disc
Sep 04, 2009 | SimpleTech Signature Mini 320GB External...
Usb broke off my seagate 320gb external
it does'nt really matter IDE or SATA both are using same connector. you can change it from second hand or from another board sometimes its not available.
Sep 02, 2009 | Western Digital 320GB MyBook External USB...
MyBook's power light is blinking, but not showing up on my Mac's desktop
Data recovery usually will cost about 2000 - 3500. i may be able to help as long as the platters aren't physically damaged. Send me the drive at your cost. I will pull all data and return data on burned dvds I keep the drive. If i can't retrieve data then i will return drive to you at my cost. jprusso@yahoo.com
Jun 01, 2008 | Western Digital 320GB MyBook External USB...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
