Question about Panasonic Microwave Ovens
Cutting out after 30 seconds - Panasonic Microwave Ovens
  • Panasonic Master
  • 9,086 Answers
Is it more like 22 seconds?
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
Panasonic NN-S563 no heat
hmmm...well..did you do a power setting? that is what is needed in the sequence just stated..try one of the presets like popcorn, to see if that works.
Oct 19, 2008 | Panasonic NN-S563 Microwave Oven
My bosch innowave stops after like 30 seconds...power just cuts off and food doesnt get warm
Hi There,
Unplug your microwave for ten minutes, plug it back in, and test it on a cup of water. If the problem persists, you'll have to take it in for servicing or buy a new microwave. I don't recommend continuing use if it's turning off on it's own, that usually means a bad power supply and can result in curcuit damage.
Jun 06, 2012 | Bosch Microwave Ovens
Microwave cuts off after 30 seconds
We would need to know the brand and full model number to be sure, but since you posted in the Panasonic section, I'll assume it's a Panasonic.
Panasonics have preset times in which it will shut off if certain failures occur.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 12, 2011 | Panasonic Microwave Ovens
GE microwave/convection oven 1790 there is a #8 displayed in the right upper corner of display
HELLO.
When the F8 code appears,it means that electric control requires replacement because the relay drive circuit has been lost.
Attempt to clear the code by pressing Cancel and cutting power to the range for 30 seconds.
If the code cannot be cleared, replace the electric control.
thanks.
Sep 21, 2011 | GE JVM1790SK Convection/Microwave Oven
Operates for 30 seconds, no heat, cuts off
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 20, 2011 | Microwave Ovens
MY GE SPACEMAKER MICROWAVE CUT OF AFTER ABOUT 5 TO 10 SECONDS
might be a short in the system to cook the food or a short in the board for it if there is i would recommend in getting rid of the microwave or getting it fixed otherwise its a big fire hazard for ya
Hope this helped ya
Cheers
Johnthetr870
May 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
