Question about Sony CDX-F50M CD Player
No power to unit 10 amp fuse checked and replaced
    Brigadier General:
  • 6,966 Answers
To my knowledge, it would take two types of B+12 supply to turn on the unit; a constant/always on +12 on the yellow wire and a switched B+12 on the red wire (such as from the ACC terminal of the IGN switch.
If both B+s above are present and the grounding (black wire) has been verified to be connected to the chassis/ground, then it is an internal fault of the Sony CDX-F50M. This of course require that the unit be un-installed and diagnosed/check/repaired.
Absence of any of the two B+s would require tracing where the supply is not present. A DVM wold be handy for the check.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 16, 2008
Gen set blows fuse
no
a fuse is there to protect the circuit and the genset
check why the de-icer is pulling so many amps as the problem may be in that unit
a 10 amp outlet has a maximum current capacity of 10 amps as that is the current allowable from the gen set and wire capacity
even if you had an outlet with 15 amp rating , it would still be blowing fuses as the 16 amps is above the allowable current draw
you would need a 20 amp outlet ( difficult to get unless it is in a house power board and are normally reserved for hot water systems , stoves and other high current usage units and are normally then not outlets but hard wired in to a circuit breaker
Aug 10, 2016 | Kohler Electrical Supplies
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
How do I fix my Endurance Treadmill TF3i Err7 problem? I stopped during operation.
Unplug unit remove motor shroud check connections on lower board (incline board). I believe their is a 3 amp fuse in circuit check with multi meter to see if open replace fuse power up unit and if it blows the fuse then replace incline motor and if not, then use engine mode press stop then Incline + or - to force incline up to max incline then bring it down to 0 then turn off power then wait 10 seconds then hit power on then if error does not appear then hit start and resume using unit. If the procedure above does not activate unit then replace board.
Apr 15, 2010 | Endurance T3 Treadmill
The unit won't power on at all.
You can try replacing it with any 10 amp fuse just to see what happens. If a new fuse keeps blowing out then you have a shorted power amplifier inside(they consist of transistor or a single chip). These device look normal most of the time short out with any visual indication. If you desolder the power amp chips(they are mounted against an aluminum heat sink to dissipate heat) and the fuse quit blowing then it is the problem.
Aug 11, 2009 | Samsung HT-TX72 Theater System
Nissan maxima 1996
moz-screenshot.png#1-10 amp
SRS (Aribag)
#2-15 Amp
Air conditioner
#3-15 Amp
Air Conditioner
#4-7.5 Amp
A/T TP/Sw
#5-Tail LIght, Turn Signal Switch
#6-15 Amp
Horn
#7-10 Amp
Power Mirror, Mirror Heaters
#8-10 Amp
#9-10 Amp
#10-15 Amp
Power Windows
#11-10 Amp
Turn Signal
#12-7.5 Amp
Power Windo, Door Locks, Sunroof, Time control unit
#13-10 Amp
Meter, ABS, ASCD, Back-up Lights, Air bag, Warning Chime
#14-7.5 Amp
Corner, Turn
#15-10 Amp
ABS
#16-7.5 Amp
#17-10 Amp
A/C, Fuel Pump, Canister, EGR, Cooling Fan, ASCD
#18-7.5 Amp
Illumination
#19-7.5 Amp
Wiper Motor
#20-20 Amp
Wiper washer timer
#21-10 Amp
Horn, Audio, Power Antenna
#22-15 Amp
Audio
#23-10 Amp
#24-10 Amp
#25-15 Amp
#26-7.5 Amp
Step/L, Room
#27-10 Amp
#28-7.5 Amp
#29-7.5 Amp
Heated Seats
#30-20 Amp
A/C
#31-10 Amp
#32-15 Amp
Fuel Pump
#33-10 Amp
Theft Warning System
#34-10 Amp
Fuel, RO2H
#35-15 Amp
#36-7.5 Amp
#37-10 Amp
TLID, MULTI
#38-7.5 Amp
Rear Defogger
#39-7.5 Amp
Rear Defogger
#40-20 Amp
Door Lock, Horn, Multi, SRS, Power Antenna, Timer
Aug 01, 2009 | 1996 Nissan Maxima
Sharp ar 122 ccd trouble how to repaire
Sharp AR-122 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 23, 2009 | Sharp Office Equipment & Supplies
Paper tray will not go up or down. Cannot get it to move.
Sharp AR-650 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 19, 2009 | Sharp AR-650 Copier
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Galaxy Dx-88 HL
anything over 10 amps should be sufficient i would assume. if it calls for a 10 amp fuse anything less than that would be under powering the unit
Nov 07, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
Sony CDX-F50M CD Player Logo
132 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
