Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Lights went out on my bosch washer and i cant get clothes out
Ran a load of clothes in the washer went to check on them and all the lights were out and door locked. I check the breaker and it was fine, I tried unplugging the washer and then plugging it back in still no lights. I opened the service door and drained out what i could of the water but still dont know how to get the door open. Any suggestions?
  • 487 Answers
I unfortunately was not able to get the service manual for this machine but as far as I remember there is an internal fuse in the bosch nexxt.
Will be lokated where the power enters the machine or on the control board.
Posted on Jul 17, 2008
  • eric bosman
    eric bosman Jul 17, 2008
    Please check all the wiring entering the machine. It can be that one off the conectors losend due to the spin. If it does not work after that it might be the the control module.
    HERE is where you can see drawings and you can order parts
WHY IS my bosch maxx 6 CANT SPIN THE CLOTHES OR DRAIN THE WATER ?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Maxx 6 WAB28260GB White 600 mm...
Bosch 100 series washer will not spin or agitate
Cleaned out the drain hose from the front panel. Seems to be working fine now.
Thanks
Oct 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Wont drain
First Try Unplugging the washer for 15 minutes. Sounds like the pump is the issue. Was it a normal load of clothes or a Bath rug or blanket?After you plug the unit in try to select rinse/drain Or drain/spin.
If it starts try to cancel the cycle. The washer should drain the water out for you. Pls update when you can.
Sep 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine is not spinning
check the carbon brushes in the motor or the belt.if its not these then it may be a timer fault see if you have power to the motor
Jun 02, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosh wasmachine doesn't was clothes
Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
Mar 23, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch washing machine not drawing water
you probably have the "burst free" hoses, this machine draws water too fast so the hoses think they burst, change the hoses to the original or get new ones that aren't burst free and this should solve your problem
Apr 29, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Seals keep ripping out on the washer, which causes other probs
info from a bosch tech. alot of times the boot gasket gets ripped from clothes not put in machine fully. and also the basic take things out of pocket. I remember fixing a washer and the customer sworn up and down that she didnt have anything in her pockets she check every wash the whole nine. so after i manually drained the unit guess what i so. 3bobbi pins and 2 pennies. so just be very careful with what you load. sometimes clothes get stuck between the gasket and the tube,
Apr 19, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Apr 13, 2008 | Bosch Washing Machines
Spin=wet drippy clothes
if it shakes so hard it makes me wonder if one of the dampners is lose. If yo haven't moved it and it normally worked ok than that will be the thing. It leaves it wet because the machine cant get to the high rpm's because of imbalance
Apr 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Washer
In due course they will land up in your outlet filter. It wuold be good to check all pockets, etc before loading the laundry into the machine.......I am talking about your washer; no comments about the dryer.
Dec 06, 2007 | Bosch Classixx WVF 2402 Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
447 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
