Monitor 2 - Image is upside down and backwards
Whether playing a separate dvd or sharing dvd with the main player, the 2nd monitor image is upside down and backwards. I've unplugged, etc., removed power source and started all over, and occasionally the image will go back to normal. Then for no reason, it's upside down and backwards. Any ideas? NO STEPS TAKEN
Check your graphic card settings. I have a 6600gt, and can invert my screen. Try going: right click your desktop, select properties. Go the settings tab. Clieck advanced. There do you have a tab for your graphics card? Mine shows I have a 6600Gt. After selecting the tab it displays options. I have NVrotate. That rotates my screen.
Posted on Jul 16, 2008
Image on monitor is upside down!
most the time pressing CTRL ALT UP ARROW together will flip the monitor back right side up
CTRL ALT DOWN ARROW will flip the screen upside down
Dec 05, 2009 | Acer Computers & Internet
DVD plays upside down adn backwards
Re-check the wires to start with mate
May 31, 2009 | Car Audio & Video
Capcom Midway 1943 - big old arcade game
As silly as it sounds, you can probably just open the cabinet and flip the monitor over to get the picture in the correct orientation. Quite frequently arcade machine operators change out the system boards in their cabinets to keep up with the times. If they have a cabinet with an older, less desirable game in it, they'll swap it out for something newer in hopes of earning a few more quarters each week. Once in awhile they'll swap a game that has a vertically oriented monitor (like your 1943 cabinet) to something that's horizontally oriented (like Street Fighter for example). How do they pull this off? They simply open the cabinet and turn the monitor in the correct direction so the players can see it.
If you decide to turn your monitor, here's what to look out for:
First, unplug the arcade machine to avoid electrical shocks.
Monitors are somewhat fragile, and can be extremely dangerous. There is a coil of unshielded copper wire near the neck of the tube that stores charges in excess of 10,000 volts (even when the machine is unplugged and powered down), and can severely injure/kill you if you touch it. I've personally worked with thousands of monitors and haven't had an incident yet. Odds are you'll be perfectly fine, but just be aware that there are dangerous parts back there.
The monitor should have 9 wires going to it broken down into 2 bundles. The power bundle will normally have 3 wires (green, black and white) and will be a thicker gauge wire than the other set. These almost always have a white plastic connector that makes it simple to disconnect them.
The second set of wires will be the image signal wires. These will be a smaller gauge of wire and they'll be red, blue, green, white, yellow and black (in most cases). These wires also have a white plastic connector, but it's often times plugged directly into the monitors main circuit board (or chassis). Just pull the wires off of the chassis making sure you don't damage any of the components (or yourself!)
Once you've disconnected the wiring, it's simply a matter of finding the bolts that hold the monitor in place, removing them (along with the monitor) and flipping it over. The monitor should go in just as easily in either direction. Reconnect the wires, fire it up and off you go!
Apr 24, 2009 | Video Game Consoles & Games
My screen
It is telling you that, depending on the rear-view camera that is attached, the image MAY appear reversed. If the unit is going into this screen on it's own, go to the main menu screen where you would choose DVD, RADIO, AUX, etc... and press Rear View. It should beep (but not change). That is it.
Jan 20, 2009 | Pioneer AVH-P4000DVD Monitor
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Reverse image wtih evp-70fh monitor
IN THE SCREEN SETTING TURN OFF MIRROR IMAGE
Feb 12, 2008 | Car Audio & Video
The movies are playing upside down
If you press and hold the mode button it will cycle through 4:3 , 16:9, after 16:9 it should flip over.
Thanks
Dec 16, 2007 | Polaroid PDM-1040 Portable DVD Player
Image is UPSIDE DOWN! Polaroid PDM0722 DVD Player
My kids were pressing all the buttons on the dvd playing. The image flip and I was clueless on how to fix it. I held the mode button for a few seconds and it corrected the problem.
THANKS!
Oct 22, 2007 | Polaroid PDM-0824 Portable DVD Player
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
