Question about Sharp Office Equipment & Supplies
My sharp MX2700 copier shows troubl code E7-21.how to solve this problem.
  • r_senarath Jul 16, 2008
    pls help me to sole the problem of mx2700 sharp copier.it shows error E7-21.
    thanks
    ravinda.
Use crop code 14
Posted on Oct 27, 2008
How can I solve the problem of l4:02in sharp copier mx2700
L4-02 means paper feed motor lock. Check connectors, wire harness between PCU board and feed motor.
Aug 19, 2016 | Sharp Office Equipment & Supplies
Sharp ar 5516 error code f2- 40 - Sharp Printers Copiers please help me how to solve this problem
oner supply abnormality: connector harness trouble, control sensor trouble, toner seal not removed.
Jul 13, 2016 | Sharp Office Equipment & Supplies
Why is sharp mx2700 black ghosting ?
Check the fuser assembly and make sure the 2 levers for envelope printing are not engaged. They reduce the pressure between the fuser rollers and then the copies get issues like that. If that doesn't fix the issue Could be the drum or the transfer belt cleaning assembly causing this problem.
Sep 04, 2014 | Sharp MX-2700N Color Copier
Mx2700 replace waste collection container
You need to replace or dump the waste container. Flip down the main front cover on the front and you will see it
Jun 26, 2014 | Sharp MX-2300N Color Copier
Sharp ar5516 error e7
with such error displayed press the print button, the machine shows another sub code, if it is 11 or 12 means a trouble with the scanner section.
to fix take out the glass ,clean the white strip left, the lamp reflector and mirrors, open the lens cover (5) screws, clean the lens and CCD.
if the subcode is 16 a trouble with laser
Nov 18, 2011 | Sharp Office Equipment & Supplies
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
The Sharp MX2700 Colour machine has come up with an error code DK, what does this code refer to.?
This code means the Black Developer powder has reached the end of its life A service call will be needed to replace this for good black prints
Apr 26, 2010 | Sharp MX-2700N Color Copier
Sharp MX2700 reading offline I cannot print
had same issue found solution as follows
Go into port settings of printer, click configure port remove tick for 'SNMP status enabled'
Soon as we did this printer came back online
Nov 01, 2009 | Sharp MX-2700N Color Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
