Question about Honeywell Heating & Cooling
I changed the batteries and now the house will not cool down. The lowest i can get the house cooled to is 76 degrees, and that is if i turn the thermostat down as low as it will go. The air coming out of the vents isn't really cold.
  • 1,420 Answers
Check the filters. Clean or replace them. If you are refering to the batteries in the remote, look for a reset button or hole and stick a paper clip in it. You will have to reset your clock.
Posted on Jul 17, 2008
Wont let me change temp. below 76 degrees on arcticpro
76 f is 24 celsius which is optimum temperature for comfort
Jun 05, 2016 | Arcticpro Ypc-07c Faac7 Portable Air...
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
User manual for jnc JAC-24Y2???- want to know what the optimal setting for heating temp is for economy in the unit. We seem to have to have ours set quite high to get the unit to run consistently. If we...
Normal settings 70 heating 74 to 76 cooling, I try to leave my cooling a 76 and keep it there. 76 degrees feels good if its 95 or hotter out side and the lower you set it the more it will cost.
Jul 03, 2011 | Heating & Cooling
At what temperature do I program the thermostat for a comfortable cooling(at how much do set the cool and h ow much should I set the heat). Thanks for your help
Normal settings are heat 70 and cooling 74 to 76 I like 76 if your not active its fine. They say the every degree above 70 heat cost additional 5%.
Jul 02, 2011 | Honeywell Programmable Thermostat Heater
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Message: "in recovery"
the "in recovery mode" is refering to a thing called energy recovery management its one of the features on your tstat what it does- when you are using the program on your tstat the "in recovery" starts your unit early so if the tstat is set to be 70 degrees at 8 in the morning when 8 o clock hits it will already be 70 degrees in your house you can turn this feature off if you want in the installation setup codes
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Getting cooler air
if you are desiring to have it 62 degrees in the house, the cool setting needs to be more to like 66 deg and the heat setting needs to be like 58 degrees. that would make it more around 62 degrees in the house.
change the heat setting first to 58 and then change the cool setting to 66. this gives your temperature 62 +/- 4 deg.
Jun 16, 2008 | Computers & Internet
Heating & Cooling Logo
53 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
