Question about Fujitsu Siemens AMILO Pro V7010 Notebook
EMachine won't complete restore, clocks on "What is the name of your computer"
I have tried multiple times to restore my pc with the eMachine Restore DVD's, however, when I get to the part that asks "What is the name of the computer" I am able to enter the name and when I hit next it will clock or just stop doing anything. I guess the windows XP setup has a problem. I first thought that my hard drive had a problem, but I don't think the process would have gotten this far
    Genius:
  • 2,028 Answers
There is a good possibility that the disc is corrupt. First try a different disc or test your disc in another machine. However, you can't totally rule out the hard drive yet. If the hard drive has a bad or failing sector, it will do the exact same thing. Most of the time when I run into this type of problem it's the disc. Another way you can check the disc is to copy the disc or make a disc image to the hard drive. If the disc hangs up or won't copy or make an image then the disc is corrupt. This will have to be done on a different computer with burning software, obviously.
Posted on Jul 16, 2008
Need to restall windows 7
Have you tried your recovery disk or boot in safe mode?
Jul 02, 2013 | Acer eMachines Black EL1352G-41w Desktop...
My desktop pc will not go to factory restore setting
Most people who own an eMachine computer will find that they will need to reset the computer at some point. It is a fact that PCs are more prone to viruses and malware than Macintosh computers. Sometimes the only way to restore an eMachine is to simply reset it. Fortunately, it is not a difficult process to reset an eMachine computer.
Turn off the computer. If the computer is in a state that it can be properly shut down, follow the normal shutdown process. On the other hand, if the computer is not reacting to anything, simply pull the cord from the wall. Restart the computer. Plug the computer back into the wall and press the Power button. Wait for the eMachine to reach the screen that reads "Press F11 to start recovery." Once this screen appears, press the F11 key on the keyboard multiple times to make sure that it registers. If the recovery screen does not come up, you will need to turn the computer off and back on again and attempt to press the F11 button again when the prompt appears. Select the proper option. After the recovery screen appears, there will be a list of recovery options. Scroll to the option that says "Full System Restore (with Backup)." Choosing this option will copy all of the contents of the hard disk to the c:\\My Backup directory. This will ensure that important files that have been created on the computer will not be deleted. However, the applications on the computer will need to be reinstalled. Allow the system restore to run its course. Depending on the age and effectiveness of the eMachine computer, it is possible this process could take up to 45 minutes. When the system restore is complete, the computer will restart itself. Reinstall applications. Any of the files created on the computer should be saved. However, the applications that created them need to be reinstalled.
Emachine Support
http://support.gateway.com/us/en/emac/default.aspx
Mar 16, 2013 | E-Machines eMachines Desktop PC
El1210-09 won't shutdown
Step 1:
b>
Feb 07, 2013 | eMachines EL1210-09 PC Desktop
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
How do i restore my emachine w3619 without a restore point or ****?
If your trying to restore your machine back to factory setting then you can follow the steps below: 1. Go to start menu 2. Click on all programs
3. Click on Emachine
4. Click on Emachine recovery management
5. Click on restore on the bar across the top
6. Click on restore to system factory default or 1. Turn OFF you computer 2. Press and Hold ALT key then tap F10 8 times immediately after you turn you computer on. Hope this information will be helpful. Thank you forusing FIXYA.
Apr 16, 2011 | eMachines W3619 PC Desktop
Restore
  1. 1 Place the recovery disk that came with the eMachines computer into the CD or DVD drive. Restart the computer.
  2. 2 Click "Next" when the operating system restoration screen appears. Click "Repair Your Computer" and then select "Next."
  3. 3 Locate your eMachine's current operating system in the list of available operating systems, such as "Windows Vista." Click the appropriate choice and then choose "Next."
  4. 4 Select "Load Drivers" and wait for the drivers to finish installing. Select "System Restore" and then click "Next."
  5. 5 Scroll down through the list of available restore points. Select the first restore point if you want to completely revert the computer to factory settings. Select a later restore point if you just want to roll back any changes to your computer to an earlier date.
  6. 6 Click "Next" and then select "Finish." Click "Yes" and then choose "Restart" to restore the eMachines computer.
Jan 10, 2011 | eMachines ET1161-07 Desktop PC
How do i restore my emachines w3619
Jan 09, 2011 | eMachines W3619 PC Desktop
I have t3504 emachine and am trying to restore
try replacing your hard drive. the do the restoring again.
Jun 03, 2010 | E-Machines T3504 PC Desktop
Procedure for total pc restore on emachines T5085
Did you receive a restore CD along with your eMachines computer when you purchased it? If you have such a disk, that is the easiest way to do a full system restore. If you do not have this disk, you can obtain one via emachines support. This is the most recommended method for a full restore. If your machine boots up fine, you can check to see if you have a restore point in the Windows System restore. If you ever had to turn the system restore off (for virus removal or something), you will not be able to to a complete restore this way.
Good luck
P.S. If this information was helpful, please rate this solution. Thanks!
Dec 03, 2008 | E-Machines (T2824) PC Desktop
E machines restore disc
hit f11 when computer is starting up..it will take you to the restore menu...do a complete system restore from the restore partition.. as far as the restore discs goes, when you pop that in, the computer will boot from the cd and take you to the restore menu...do a complete system restore..after formatting the hard drive.it will show a bunch of files..be patient and let it complete the process...
Feb 23, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
151 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
