Question about Kenmore Elite 45986 Front Load Washer
Front Door Seal/Baffle Replacement
I need to replace the main baffle/ rubber seal around the door of my Kenmore Elite HE4T model #11045089401. Can you assist me with instructions on how to replace this rubber?
  • 1 more comment
  • wcnie Jul 19, 2008
    I am also looking for replacement part and instructions for HE3 - the gray rubber boot has a tear causing water to leak all over the floor
  • yambaws Jul 22, 2008
    same here with the tear. I used a bicycle tire patch kit to glue it back together I will let you know if it works. I looked on the sears site and can not for the life of me find the right replacement part. Oh well If all else fails I will call them.
  • Anonymous Mar 22, 2014
    rubber seal
I need to replace a baffle from inside my Elite HE3T. Do you have directions? Only 1 came off but when I order the new one apparently it only comes in 3, so show I replace the other 2 as well? (if I can figure out how)
Of course the part did not come with any! And Sears customer service is of no help and the technical people have not responded to me.
Thanks,
Posted on Aug 27, 2008
Ways leak from the bottom when you start the wash
this may be something stuck in the gasket(rubber) that seals the door. Fold down the gasket all thew way around the gasket, remove any thing hat may be there. This could be coins, small articles of clothing, or a wash cloth.
If no obstruction is found, it probrbly require replacement of the door gasket/seal.
Mar 27, 2011 | Kenmore Elite 45986 Front Load Washer
I recently purchased a home which this washer was included. It has a moldy odor. I cleaned it out under rubber ring but seems to keep coming back. What can I do?
The door seal will need to be replaced. Once the mold sets in deep it will keep reappearing every couple weeks or so. Here is a link that will help with the door seal. It's a different model but a similar procedure would be used. Replacing a door seal
Nov 05, 2010 | Kenmore Elite 45986 Front Load Washer
Washer door leaks
The front baffle/boot will likely need replaced. You can do this yourself but it takes some patience. You can order the part, list model #, at 888-321-3107. The procedure is as follows:'
1. Tilt washer, back against wall.
2. Remove wire spring with needle nose plyers. The spring is located at outside perimeter, under lip, of baffle.
3. Peel baffle from front panel.
4. Remove clamp from the outer tub lip. Look closely and you should find a large hose clamp. Use small socket wrench to loosen.
5. Install in reverse order. Be careful and take your time.
Rich
Western Appliance Repair
Washer Repair
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Small **** in the rubber molding inside the door; leaking.
You may need to replace the door seal. But first take some 100% pure silicone and push some in the hole and around the hole. Let this dry for 24 hours before using this should seal it up. If this does not work replace the door seal. Here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Jul 12, 2010 | Kenmore 42822 Front Load Washer
The door is leaking when the washer is in use
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Although the bellow may not have any physical tears, they can also become mishapened over time due to normal wear and not seal properly. You should have a good tight seal all the way around the door.
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The first three sites have excellent exploded view parts illustrations you can use for part location and assembly. Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Some additional items to look for that may cause leaks around the bellow:
1. Check the dispenser tubes that pentrate the door bellow. Sometimes they get pushed behind the rubber causing the water to trickle behind the bellow and leak. You will notice this on fill and rinse.
2. Check the rear bellow clamp that holds the seal to the front facing of the wash tub. The clamp can come loose, causing it not to seal properly.
Dec 31, 2009 | Kenmore Elite 45986 Front Load Washer
The boot seal/tub seal is torn and I want to replace this piece
door boot or baffle as it is sometimes called can be replaced. however it is not an easy job as there is a large spring that hold it on.
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Water leak????
umm the leak is coming from the seal within the front of dispensor??? i checked my partlook up and comes back as a seal( part number 8181747).. sears site has it listed as distrubution nozzle(mis marked)
Oct 28, 2008 | Kenmore Elite 45986 Front Load Washer
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,120 people viewed this question
Sal De
fordexpert
Robert Rankin
