Question about Fargo 4250 Thermal Printer
Color print out of place
I'm currently having problems with the print-out.The print's colors is out of place. Can anyone tell me how to align the color ribbon (which color should by the print head before printing)
Assuming you are asking about colors out of alignment, usually this is due to the card slipping and returning to the corrent position in each pass. I have corrected this problem by thouroghly cleaning all the rollers with an alcohol wipe. With the cover open and the ribbon removed, firmly hold the wipe against the two gray and one black roller while depressing the forward and reverse [power & online buttons] and allowing the rollers to run several revolutions against the wipe. I just use typical medical or first aid wipes, no need for fancy equipment wipes. The alcohol rejuvenates the rollers and keeps them sticky so to speak, so the card is moved correctly. To clean the feed roller, send a card or self test from the driver to the printer with the cover open and the ribbon removed. While you are at it, use a wipe to com[letely clean the metal interior of the printer. Cleanliness is next to godliness when it comes to these printers. ~ Jon
Posted on Aug 16, 2008
Problem with color alignment on DocuColor 1632
Below is a link to the user manual, the aligment procedure should be in there. Xerox DocuColor 1632 User Manual
Jun 16, 2017 | Xerox DocuColor 1632 Laser Printer
My printer is reading check alignment, is it because my color cartridge is out of ink?
No, that's not what it means.
If printer heads are not aligned, CMYK colors (Cyan, Magenta, Yellow and blacK - the usual colours in a printer) will not print in the correct place.
Assume a dark grey dot is to be printed. For this C, M and Y colored dots have to be placed exactly on the same spot. But if heads are not aligned, the three color dots will not be exactly in the same place. Therefore you will see Cyan, magenta and Yellow dots adjacent to each other instead of one dark grey dot.
It is always a good idea to align the print heads every time a new cartridge is installed.
Sep 23, 2011 | Lexmark X3650 Printer
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How to configure printhead alignment
Hi there, Aligning the Print Head
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
Hope this help.
Have a good day.
Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
When I change the black ink cartridge, the alignment page and instruction page are printing out fine. When I place the alignment page on the glass as instructed and press 'ENTER', the printer gives a...
I just had the same issue (align page not detected).
We had just re-installed the empty color cartridge back into the printer (long story but basically we knew we could only print B/W).
The align page printout had a lot of empty spaces around the black lines. This is apparently where the color lines are supposed to print.
Without those color lines, the printer would not detect the align page as color is part of the alignment being done.
Since we only wanted black printouts, I pressed 'cancel' to stop the alignment process, and now we just hit the Black copy button and ignore the alignment prompt on the printer window.
The HP site (enter psc750 in product window) has some helpful ideas as to what the problem might also be. It could be the shipping tape is still on the new cartridge (and preventing the black or color from printing on the align sheets) etc.
Mar 20, 2009 | HP PSC 750 All-In-One InkJet Printer
Mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp 2600n color printing problem
are you using orgnial hp cartridge if not check that it may cause due to that. check the black sheet fro color spreading , if there is any color pls clean that.........
Thank you
Feb 19, 2008 | HP Color LaserJet 2600n Printer
Fargo 4250 Thermal Printer Logo
127 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
