Question about Dell Dimension C521 PC Desktop
Hi Have a Dell Dimension 8200 trying to increase memory Original is 2x128 plus 2xcontinuity Purchased 2x256 and installed but computer will not work.Is it the case that I can only install another 2x128 to match the existing 2x128? Must the original cards always be installed?
  • 3 Answers
On a Dell Dimension 8200 there were 2 available bus speeds, 400mhz and 533mhz. The bus speed determines the required RAM speed. Most common 8200's have a 400mhz fsb and require a RAM speed of 45ns or faster (Lower number = faster). Some 8200's have a 533mhz fsb and require a RAM speed of 40ns or faster. The RAM modules must be installed in matched pairs, but the 2 pairs do not have to be equal to each other. (I have 8200 with 2x512mb and 2x64mb - you can also mix ECC and NON-ECC pairs but it will disable ECC) Check the last 2 numbers on your original RAM that works in your system, they will be either 40 or 45. If they are 40 - and 45's won't work, you have a 533mhz fsb. If this is the case, buying the same RAM in a 40ns speed will solve your problem...... Hate to be the one to break it to you, but if you do need 40ns (Rambus) RAM, it is very expensive - about 4 times the price and 1/10th as common as 45ns RAM. Some good deals can be found on ebay - search: rambus 40ns.
Hope this helped, and good luck :)
Posted on Jan 16, 2009
I am getting ready to intall additional Rambus memory to my Dell Dimension 8200 and need walked through it... Any help?
Hello d_silverthor,
Here's a video link shoing how to install memory in a Dell Computer:
http://www.memorystock.com/memory/viewvideo.asp?systemtype=Dell+Desktop&Class=Desktop
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Dell Dimension 8200 PC Desktop
I want to add more ram. Where do I get it? Dell
I hate to be the bearer of bad news, so don't 'Shoot the Messenger'!
The Dell Dimension 8200 Desktop PC uses RDRAM ram memory.
VERY expensive stuff!
Supporting Data:
This is Dell Support, Manuals, and the Dimension 8200 Service Manual,
http://support.dell.com/support/edocs/systems/dim8200/
Scroll down the list to the heading - Specifications, and left-click on it.
Scroll the page down until you come to the heading - Memory
Now look at the first subheading - Architecture
RDRAM
You have 4 ram memory slots. (memory connectors)
EACH, ram memory slot can support up to a Maximum amount, of 512MB. (512 MegaBytes)
TOTAL Maximum Amount for your computer is 2GB. (Not shouting)
1024MB = 1GB. (1024 MegaBytes = 1 GigaByte)
The type of Rdram ram memory is PC800, and it is Non-ECC.
(Error Correcting Control, or also stated as Error Correcting Code.
Used mostly for Server computers. Your computer does not use ECC ram memory)
In My Humble Opinion, (And again, don't shoot the messenger), it would be better money spent to buy a decent affordable computer, than it would be to upgrade the ram memory in this computer.
This statement is based upon the fact that the Dell Dimension 8200 ships with 128MB's of ram memory.
(Makes it a pretty slow computer. Rdram or not)
The average cost to install, for example, 1GB of ram memory is OUTLANDISH! (Not shouting)
Example 1:
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=24927
Example 2:
http://www.pcmemorystore.com/Dell-Dimension-8200-ram.htm
For about another $100 you can buy a pretty decent new desktop computer, that will run the one you have in circles.
Just my thoughts.
Dec 07, 2009 | Dell Dimension 8200 PC Desktop
Possibility of using Dimension 8250 memory in a Dimension 8200
Probably not, but to confirm go to this link. When you're there plug in the info for both machines and compare the memory configurations.
May 25, 2009 | Dell Dimension 8250 PC Desktop
"my computer will only beep no screen,it beeps
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Mar 14, 2009 | Dell Dimension 8200 PC Desktop
Dell Demision 8200 just beep
Kindly follow the troubleshooting steps on the following steps
http://tinyurl.com/dgb5x5
Chances are that you have a loose memory modules
Thanks
Proton
Mar 12, 2009 | Dell Dimension 8200 PC Desktop
How to add memory to dell dimension 8200
http://www.tigerdirect.com/applications/category/memory_config.asp?ClsId=100
Enter the following information in the blank
and you should come up with which ram is compatible with your computer
then refer to this link on how to install the ram into your computer
http://static.tigerdirect.com/html/guide_installing_desktop_memory.html
Dec 30, 2008 | Dell Dimension 8200 PC Desktop
Restore factory settings
If after hit control F11 nothing happen, probably you don't have a restore partition. Check that first.
If not you need to reformat your drive by reinstalling windows (you DO have that cd) and then reinstall the additional software that came with your 8200 (all that stuff is downloadable from dell website)
Nov 19, 2008 | Dell Dimension 8200 PC Desktop
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
Dell Dimension C521 PC Desktop Logo
85 people viewed this question
Alun Cox
