Question about Amana ASD 2624 Side by Side Refrigerator
Amana refrigerator side by side freezing on bottom on both sides. Food in upper part of refrigerator is warm. Ice melted in ice maker. Coils are clean. Compressor and fan are running. Compressor is hot to the touch. Fan in freezer is not running, although there is power to it. Unit is under 5 years old. Would this problem be with the thermostat or control board or am I way off base.
FOOD IN REFRIDGERATOR FREEZING AND WATER BUILD-UP ON THE CEILING OF THE REFRIDGERATOR,WHAT CAN I DO TO SOLVE THIS PROBLEM.
Posted on Sep 09, 2011
Evaporator fan not working
Posted on Jul 17, 2008
The ice in the ice maker melts and refreezes. The food in the refrigerator drawers freeze and the top portion is warm. What is the problem?
Sounds like the defrost thermostat is not opening and element is heating too long or the ice maker is sticking in harvest too long and the tray heater is heating too long. try turning off the icemaker for a day
Mar 26, 2011 | Amana Refrigerators
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana, bottom freezer, freezer not freezing and then refrigerator not keeping cool.. help Started with the ice maker not making ice, the sound of trying to pull water but never any ice. Then the freezer,...
Hi
Firstly put off the refrigerator before the compressor burns off.
The problem is simple... the coling gas has leaked out.... put new coolong gas...BUT only after finding the place of leak... this will be needed to be fixed first.
Regards
Berry
Feb 07, 2010 | Amana ABB1927DE Bottom Freezer...
I have an amana side by side refrigerator. The ice is building up
There is a drain hole under all of that ice that got clogged at some point and it started building up ice in that area.  The water that is freezing is coming from the defrost cycle which melts all of the ice buildup on the evaporator coil.  First melt the ice.  Then unclog the drain hole.  The drain goes to a tray in back near the compressor, where the heat from the compressor evaporates the water.
Oct 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
Oct 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ASD 2624 Side by Side Refrigerator Logo
213 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
