Question about Maytag Dryers
My maytag performa quiet series dryer just stopped working. I'm pretty sure that it may be the belt. I'm trying to take it apart. I have the front and top off, but do I need to remove the drum and how?
  • 525 Answers
This is your complaint:
"My maytag performa quiet series dryer just stopped working. I'm pretty sure that it may be the belt. I'm trying to take it apart. I have the front and top off, but do I need to remove the drum and how?"
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, disassembly procedures, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
You did not provide a model number, and since all models are different, I can only say that the drum does not need to be removed in most cases. Refer to the site link below for disassembly procedures. Note: you will need to enter your model number. This is located on the product data tag, which is affixed to your dryer.
Hope this will provide enough information to you, if not, post me back for more assistance.
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 16, 2008
MAYTAG QUIET PLUS II DRYER IS SQUEAKING
It seems to me you need a new belt that go over and around the drum in witch you put the cloth first you have to go on line and find the rubber belt to replace it, may need make and modle or part number. you will have to take the top off first by removing the screws and then the front panel - the front panel has the electric on/off switch connected to it so be careful not to pull it apart. The rubber belt fits around the drum and then is attached to the pulley/drive motor. have a vacume handy to clean up the worn off pieces from the damage belt. Reattache the front panel and top of the dryer.
Dec 25, 2012 | Dryers
Have a maytag gas front loading dryer pyg2200AWW and the drum does not turn. From what I can read from the various posting, it seems that the belt has broken. Not sure how to tear this thing apart as most...
Have a performa dryer model #pyg2200aww the problem is it dries for the first 10 to 15 minutes and then it shuts off, if we wait for 20 minutes it starts again but then it shuts off again.
Jun 06, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag Bravos dryer tearing the "felt ring" on front of drum.
Mostly likely the cause was the skid pads came off or were missed aligned. You could have also jarred the drum but it doesnt matter because you want it fixed. So take off the front of the dryer after calling your local maytag dealer and making sure they have the felt, skid pads, belt, and rear rollers (just in case you find more problems).
Once you have this apart make sure you clean it good, take out the lint catcher and vacume all of the lint. No reason to put back together a nasty dirty dryer. Make sure you check the rear felt carefully and the rollers. This is a very simple job and shouldnt take more than about an hour. Make sure you take the door off first then the front panel and you have someone to help hold your tools while you think. Have fun
Aug 03, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Apr 23, 2009 | Maytag Dryers
Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Mar 26, 2009 | Dryers
Maytag Performa PYET344ATW dryer noise problem
unplug the dryer.
Raise the lid.
Remove the front panel.
Inspect the blower wheel on the motor.
If loose on the shaft, replace it.
Inspect the glide supports on the front drom support.
Remove the drum.
Inspect the rear rollers for sticking.
Inspect the belt tension roller for wear.
Mar 12, 2009 | Maytag Dryers
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Dryers Logo
405 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
