Question about Tascam US-1641 Sound Card
US-1641 audio interface "no valid signal"
I have my US-1641 connected to the computer and have installed the driver, but the digital input status states: no valid signal. How can I fix this?
  • 2 more comments
  • Anonymous Sep 14, 2008
    same ******* problem how is it solved?
  • Anonymous Dec 05, 2008
    US-1641 audio interface "no valid signal" problem, and notify you when a new solution is offered.
  • krgailey Dec 05, 2008
  • Anonymous Dec 30, 2008
    same thing - exactly!!!
  • 22 Answers
Check the console in control panel and assign the ports ur using.
Posted on Sep 08, 2009
Can 10GE Optical Interfaces of a Switch Work upon a Unidirectional Fiber Connection?
10GE optical interfaces of a switch cannot work upon a unidirectional fiber connection. A unidirectional fiber connection occurs between two 10GE optical interfaces when one interface is Down because the Rx fiber is removed, while the other interface is still Up because its Rx fiber can receive link_Up signals from the PHY layer.
A switch determines the status of a 10GE optical interface according to the IEEE 802.3ae standard. As defined in this standard, the MAC layer of a 10GE optical can send local_fault and remote_fault signals. A switch can determine the link status based on only the link status of the PHY layer or based on the link status of the PHY layer and the local_fault and remote_fault signals from the MAC layer.
On a Huawei switch, link status of a 10GE optical interface turns Up only when the link status of the PHY layer is Up and both the local_fault and remote_fault signals are 0. When two 10GE optical interfaces are interconnected and the Rx fiber on one interface is removed, this interface goes Down and the MAC layer of the interface generates a local_fault signal. Meanwhile, the local interface sends a fault signal to the remote interface through the Tx fiber. The remote interface receives the link_Up signal from the PHY layer and the remote_fault signal from the MAC layer. Therefore, the link status of the remote interface goes Down.
S2300 Switch Thunder link com
Jan 22, 2017 | Huawei Computers & Internet
How to connect Acer Aspire 5530 to TV
If your TV is liquid crystal, or with VGA interface of the TV, the computer also WITH VGA interface don't need to buy TV card.Otherwise not only buy TV card, still need to buy a VGA connections, five meters. But VGA connections only transfer video, not transmit audio. So, you need purchase another audio signal lines, according to TV and computer their audio interface situation choose, both prominent circle mouth speakers audio signal lines. , 5 m.Also you can buy take S terminals output graphics CARDS, but it also requires TV also have S terminal input interface.
just have a try,I do not know if useful!,source from autodvdgps
Jan 09, 2012 | Computers & Internet
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
How can I connect this old relic to my computer? it only has 1 small output jack that says audio/video, however the last time I connected it to my TV i only got video. The audio only played from the...
You can get videos from this camera, or any analogue video source, into a computer. You just have to play them into an analogue video interface port. These are available as expansion slot cards for a PC, or sometimes as a USB plug-in interface. They will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You already have a lead for this, but from what you say I am not sure that it has both video and audio (there should be two or three plugs at the TV/Computer end). As an example, here is an analogue video input device I found on Amazon- LINK
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
Dec 19, 2010 | Sharp Video Cameras
I have a quite old Canon MV400i camcorder, which I am unable to get any connection indication from my new PC when I connected by S video/S video cable, the same applies when connected by the AV in/out jack...
For a camera of the kind you have, you need an analogue video input card in the computer to accept the video input, and you need to play the video into the computer while the computer records it. The PC will not recognise the camera as such, using these AV connections, it will only see a video signal. You don't have to install anything relating to the camera on the computer, but you need software running on the computer that understands the video input card and can take the analogue input and store it in a file. Yes, I know the computer stores the videos on digital tape, but the connectors you are talking about are analogue, and so is the signal at that point.
I am not sure that your computer actually has a video input interface (unless you have installed one?). Sometimes display cards have s-video sockets that are actually output sockets. In any case, video input interface cards generally come with the software required to capture input- it won't be specific to the camera.
Oct 22, 2010 | Canon MV400i Mini DV Digital Camcorder
My tascam us 1641 interface wont work with my 64 bit computer.
you can try xp7(86family). first download windows xp7 driver for tascam
Apr 06, 2010 | Tascam US-1641 Sound Card
How to connect Marantz PMD201 to computer to convert tapes
You have an analog tape recorder, so you need an interface which will allow you to plug it into your computer. This kind of interface is sometimes referred to as a USB Audio Interface. I use a Tapco Link.USB, and it works well, but there are many out there to choose from - you can use something pretty simple, nothing fancy needed.
The interface will plug into your computer via USB cable, and then you will use RCA cables to plug the PMD201 into the interface. When you play the audio on the tape machine, you should be able to select the "USB interface" on your computer as your "input device" and record on the computer. Watch on the computer recording software for input levels (meters that show sound is coming in), and set them to appropriate levels, not too low, not too high (if there is a red zone, you want to flirt with it only on the highest levels) ... don't hit "zero" if your computer shows zero as the peak level for input.
Final Cut Pro is far to complicated for what you are talking about doing. Many computers come with software already installed that will make simple audio recordings like this.
Please feel free to visit my website, rexark.com, for more information on audio and recording, as well as audio presentation and PA systems.
Good Luck!
Mar 04, 2010 | Marantz PMD201 Desktop Cassette Voice...
Dear sir, Recently i've bought a Tascam US-1641. I'm trying to get it to be installed but that seems not to work. I have followed the instructions for installing the driver of the Tascam US-1641, and i do...
You should go to
Start\Control Panel\AllPrograms\TASCAM\US-1641 Control Panel\Settings
Where you can adjust which controls you can see and how they behave.
Sep 24, 2009 | Tascam US-1641 Sound Card
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Feb 21, 2009 | Gigabyte Computers & Internet
Recognizes the midi interface but not the keyboard
Sir,
I am using lenovo system IBM & this system format, but sound card not match this system.  You are requested to please solve the problem.
Dec 23, 2008 | M-Audio Audiophile USB Audio and MIDI...
Tascam US-1641 Sound Card Logo
978 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
