Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpion aquarius extra wms 38 1200 spin drainage problem
Hi i have the same problem i tink that there is a screw from my work clothes in te inside of the machine and this is stopping it from draining can you help please
  • 57 Answers
Hi mate I recken if a screw goes into a machine it would work its way down to the pump and catch in the propeller listen to hear if you can hear the pump running if not you would have to take out the pump and take the screw out with a pair of nosesnip pilers are use a tweetors hope this will help
Posted on Jul 18, 2008
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
Hi could you tell me what AL6 means on my dishwasher and how to fix the problem, thanks
it may be the WMS is blocked, i get AL5 or AL6 at the start of the program. here is how i have fixed it the last couple of times. WMS is around £70 (in 2010) - i have that on mine every 4yrs or son - i change the WMS sometimes called the water management system or water softener. it located on the left of the machine. the floor will get wet during this repair.
you need to turn off the power; turn off the water supply; to it take the top off remove the two screws at the back of the lid. then work your way around the left hand side removing the panel retaining screws. once that is off you can see a large blue plastic 'thing' this is the WMS that you need to replace. to remove this you need to remove the screws around the inlet for the water, i think there are 5 or 6, some are revealed once cover plates are removed. there are 5 or 6 retaining the WMS; the most important are the tow at the bottom toward the middle. now gently prise off the WMS releasing the tabs and catches. do not pull it off as there are some connections still to be disconnected. As to lift the WSM at the bottom right, behind the WMS there are three pipes held on with spring clips, these need to be released. then the WMS should lift off.. replacing is the reverse of the above. i did not find it too difficult other than the last bit with the pipes but you know your abilities. Good Luck
Jun 08, 2010 | Zanussi 24 in. DE6965 Built-in Dishwasher
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Zanussi aqua pulse 6965 AL5 error
Jul 13, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Spin leak
The filter is located at the back of the machine.
Jan 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing still wet - door won't open.
not a fault with washer. i guess you are plumbed into trap under sink. the spigot you fastened drain hose to is blanked off - there are various methods of doing this including have to saw off the end of the spigot with the bread knife. possible also a fault with pump or filter
Nov 16, 2006 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
