Question about HP DesignJet 1050c plus InkJet Printer
System error 0000D8 005D0273
The printer was taking a long time to print. I was told to turn the power button in the back of the printer off and then turn it back on. Ever since then i am getting this system error and it will not do anything else. I tried to power it down several times after that and keep getting the same system error. Please HELP!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Mar 14, 2014
    my printer will only print when i power it off and turn it back on and then it will only print for about the next 60 seconds then you have to repart the process. It keeps showing errors on the bottom of my screen. Any solutions?
  • 138 Answers
Unfortunately, your error is a firmware error. Try unplugging from the wall if you can't do a normal power down. Unplug the network cable and then try plugging in and re-poer up the plotter. If the error comes back, your looking at replacing the firmware dimm. HP part number C6074-69350 on exchange or C6074-60350 new outright purchase without turn-in. Part should be available through http://partsurfer.hp.com. Below is a link for a free PDF of the HP Service Manual on your machine. When you look up your error it will refer you over to the firmware error. Go to the index at the end first as it's easier to locate the section for the error from the index.
http://www.feedroller.com/Store/Service%20Manual/DESIGNJET%201050C,%201055CM%20Large%20Format%20Service%20Manual.pdf
Hope that helps you.
Posted on Aug 03, 2008
HP Photosmart C5180 Ink System has Failed Error:0xc18a0306 Can't clear this error
Here is what you can try:
1. Turn off the power and unplug it from power source.
2. Open the right side of the printer (looking at the front).
3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
5. Unplug the power source.
6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
7. Plug in the power source and turn the printer on (Printer preparing occurred).
8. The 0xc18a0306 error should now be gone.
get more information for HP printer errors . Hope this helps you.
Good Luck!
Aug 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7260 Ink System Failure Error 0xc18a0206
1. Disconnect the Universal Serial Bus2.gif (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
10. If the error is still there replace the unit
1. Get the unit into the “Support Menu” by following the steps below
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen2.gif)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure2.gif” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
14. If the error is still there, or reoccurs replace the unit.
Good Luck
Oct 20, 2009 | Office Equipment & Supplies
C8180 Error Oxc18a0001
Hi there
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 15, 2009 | HP Photosmart C8180 InkJet Printer
Printer error Oxc18a0001
Hi there
Solution 1:
Solution 2:
Jul 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Nov 05, 2008 | HP PhotoSmart 1215 InkJet Printer
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart C6280 All-in-One i have an Error massage (Ink System Failure)it says: ink system has failed. unable to print. refer to printer...
ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
Oct 02, 2008 | Office Equipment & Supplies
Ink system failure
Do this: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 07, 2008 | HP Photosmart C7280 Laser Printer
Ink system failure erorr 0xc18a0306
Although it did not work for me, HP offered this as a solution. If it does not work, HP indicate you have a hardware fault that can only be fixed by a service engineer repair.
1. Get the unit into the “Support Menu” by following the steps below :
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
C. - Press and release the “OK” button.
Display should say “Support” and display the FW rev (something like R0616R)
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Mar 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Just got off the phone to HP and the issue is resolved *phew*. This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :)
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
HP were pretty good and were very willing to send out a new printer if the reset didn't work (as the printer is still in warrenty). Hope you get yours sorted too. Rebecca
Oct 15, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP L7580 Printer Head Problem??
I had the same problem plus had problems with message indicating "alignment failed" and to monitor the blakc/yellow print head.  The print quality was very bad in black.  It seemed to print about 1.5 lines and then skip a line. When I replaced black and yellow it seemed to get better print quality was just as bad.  Finally called HP support. These are the steps they told me to do.
1. disconnect power
2. remove all ink cartridges
3. remove and clean contacts of both print heads
4. perform simultaneously the following press 6 and # on the keypad while at the same time plug in the power.
5.  --- the printer came on (black squares on the screen) and then shut off.
6. --- was told to power up the printer
7. Printer began checking device(took a long time)
8. Printer began aligning printer (took a long time)
9. Finally finished = Message on screen "Alignment Failed"
10. Still not printing and hours later.
11. They will be replacing printer
12. Then they hit you with that you should buy a set of inkjet cartidges from them at $109.96 -  warranty 2yr, works better, etc.
13. Sent to somebody else to arrange shipping new printer.
14. Free shipping 5-7 days - big deal -  placed my work (home office) on hold.
16.  Service help - listen when it follows the script, otherwise like talking to a door  (In India).
17. Finally get transfered to somebody else and he informs me that he is not authorize to give me a new printer, need to talk to somebody else who is not there.  Advises to call during business hours.  He said that he could request that I be called back but that it could take a 1.5 days to get back to me.
18. I am going to call tomorrow morning during business hours - wish me luck.
I don't know what is awaiting but IN The Future I will not talk to anybody from INDIA - they do not have authority and do not listen (but maybe they don't listen because they can't do anything about it).
Good Luck!!
Oct 03, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
HP DesignJet 1050c plus InkJet Printer Logo
1,795 people viewed this question
Ben Johnson
