Question about Neff B1421 Electric Single Oven
My neff built in oven door does not close fully
  • Anonymous Apr 06, 2009
    same problem - the door does not close properly.
  • Neff Master
  • 3,463 Answers
You probably need to replace the oven door hinges, as the springs are weak.
Posted on Feb 10, 2009
How do you take the doors off Neff double oven
fully open door and lift up small metal stirrups on bottom of hinge then close door up to them grip door firmly and lift upwards ,there are videos on you tube for this also.
Feb 09, 2017 | Neff Ovens
How do I replace the handle on a neff oven?
1. Fully open the oven door.
2. Move the catch levers on the right and left-hand sides to the fully open position.
3. Placing the door at an upward angle toward you, grasp the door with both hands and lift it out of the hinges toward you.
4. undo the screws in each Connor & lift out the glass.
5. do the same with the handle screws, then put new handle on.
6.repeat above steps backwards.
Aug 30, 2014 | Neff Ovens
I have had both door hinges replaced on the main oven of my Neff but the door still does not close properly. What is the next step?
I would have gone straight through Neff. If it can't be fixed, your'e supposed to get a new oven out of the deal.
Apr 29, 2012 | Neff U1461 Double circotherm plus Electric...
Neff FD7903 Oven Drop down front door no longer fully closes & is getting worse - are the hinges adjustable?
I'm afraid not.
"Drooping" doors are very common on Neff ovens - I've had to replace a couple of sets - and seem very sensitive to things being placed on the door whilst in the open position, e.g. roasting tins whilst basting a bird/joint.
Replacement hinges are available - just Google your model number and the sponsored results will include several companies who can supply them - not cheap, but much less than a replacement oven.
Nov 15, 2009 | Ovens
Oven door won't close fully.
The only satisfactory solution, is to replace both the oven door hinges,\ which is a fairly straightforward job to do.
Please rate my solution.
Thanks
Nov 09, 2009 | Bosch Ovens
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
Neff b1421
Replacing the door hinges is the only solution to this problem.
Sep 29, 2008 | Neff B1421 Electric Single Oven
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Jul 22, 2008 | Neff B1421 Electric Single Oven
Neff B1421 Electric Single Oven Logo
216 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
