Sceptre X9G Komodo IV  19 in. Flat Panel LCD Monitor
Problem for Sceptre X9G Komodo IV (Black) 19 in. Flat Panel LCD...
Scepyre 17 in X7
By joniclipper on Jul 16, 2008
Are the capacitators 740uf 25v screw in or snap in?
Comments:
Jul 17, 2008
- the 4 objects in a line are the caps.. to remove them do you pop them out with pliers? And then sodier the new ones in?
Same Problem
Jul 17, 2008
-   These are the caps everyone else who has a sceptre lcd monitor has decribed . They are cylindrical....I think they have to be sodered but not sure. -   Guest
Solution #1
posted on Jul 16, 2008
Somewhat Helpful)
jgradejunk
Rank: Guide
Rating: 82%, 5 votes
Are you sure this is the correct cap? 740uf at 25v does not make much sense. Besides if this is an LCD then most likely all the caps would be radial.
Was this helpful?
Yes
No
Solution #2
posted on Oct 09, 2009
Not Rated)
Zeevert
Rank: Master
Rating: 80%, 5 votes
This board is out of my Sceptre X9G Komodo. The 740uf capacitors are clearly marked 25V. The 1200uf Caps are 10V. I ordered parts for mine to try. The darker 740 has a slightly "popped" top.
470 is about 10mm dia X 16-17mm long
1200 is about 10mm dia X 20? long
two leads on each about 5mm apart. They are soldered to the board.
Comments:
Oct 15, 2009
- My 4 capacitors came in and I replaced all 4. Monitor works fine again! By the way, these capacitors have polarity... they must be put in the correct way. There is a long strip along the side of the cylinder. Orient the stripe towards the "steel wall".
Was this helpful?
Yes
No
Popular Solutions for Sceptre X9G Komodo IV 19 in.
Questions and Unsolved Problems for Sceptre X9G Komodo IV 19 in.
Do you recommend Sceptre X9G Komodo IV (Black) 19 in. Flat Panel LCD Monitor?
Answer
Answer
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any... (More)
Answer
Tried another LCD monitor on my system , it works fine. Can anyone help?
Answer
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts... (More)
Answer
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sceptre X9G Komodo IV 19 in....:
Top Monitor Experts
Rank: Guru Guru
Solutions: 769
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
