I have a Polkadio sub that keeps blowing fuses. Model # psw 10
  • 2,071 Answers
If the fuse always blown, there is a shorted parts in the power supply section look for this short.For this symptom ,check the bridge diode there,if good ;then the regulator transistor ;then the start up capacitor.
hope this may help;
don't forget to rate;
Posted on Jul 18, 2008
What type a fuse do I use for my Psw 125 power sub
Is this a Polk PSW 125? I'd contact Polk customer service.
Here is the manual
There is some discussion here
A blown fuse indicates something wrong. I'd contact Polk.
Nov 17, 2015 | Audio Players & Recorders
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
My polk psw 10 keeps blowing the 2a fuse as soon as i plug it in ? Any solution besides the dump ?
Unplug the power, get inside it and disconnect either lead to the driver; stand back and plug it in to see if that helps. If so, the woofer is shorted and can be replaced failry cheaply. Otherwise it's probably more complicated and expensive for a hands-on tech to isolate the electrical problem.
Dec 23, 2010 | Polk Audio Audio Players & Recorders
The required fuse is 1.6 A / 125V an is blown, I wen to radio shack and bought a 1.6A/250V and it has blown 2 already, what can I do or check to fix it? This is a Sony Sub-woofer model sa-wmsp1.
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Jan 08, 2010 | JBL PSW-D110 Speaker
My sub has no power, ther could even be other problems i'm not aware of. so i would like to fix power first
Hiya, start by checking the power cable, then check the fuse in the unit on the pcb. If blown, replace and if it blows again then problem could be either Power supply or the amp outputs. If it doesnt blow, stays on but no sound, problem also likely to be output stage. You will need someone with experience to check outputs, etc and a meter though. Hope that helps a bit.
Best of luck
Jul 15, 2009 | JBL PSW-D110 Speaker
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
PSW 10 Not working
Your 2A 250v slow-blow fuse is blown, located under the back pannel. Mine just did the same thing. Problem is the problem with my PSW10 goes beyond the fuse. I have contacted Polk tech support to help me trouble shoot.
Sep 06, 2008 | Polk Audio PSW10 Subwoofer
I would suggest to check the rectifiers first, very unlikely that the capacitors became shorted.
Sep 04, 2008 | JBL PSW-D112 Speaker
Power not working
If it is fused check to see if the fuse is blown... Start with power and work you way down from there.
Power to the sub.
Signal to the sub
Cabling to sub
Check the speaker itself to see if it is good.
Aug 16, 2008 | JBL PSW-D112 Speaker
JBL PSW-D112 Speaker fuse blow immediately after replaced
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
Jun 27, 2008 | JBL PSW-D112 Speaker
