Question about Motorola Mobility Rugged Cordless Shop Phone With MemBrane Keypad. Ideal for Work Shops
How to use your handsfree device with your phone
Bought handsfree headset for motorola phone Package has no instructions for using Can you help?
    Master:
  • 497 Answers
Ur hands free is easy to use...u vil just have to plug in the hands free accessory to ur mobile into the given socket.
if u r using a bluetooth device, u vil have to active ur bluetooth in ur mobile and star search, simultaneously u vil have to swith on ur bluetooth too..in ur mobile u will be asked if you wud want to bond with the device..it might also ask for a passkey which is normally 0000...once u r done ur bluetooth vil be ready to use. if u r having more problems or need more assistance..plz update me...also let me know the model no of ur mobile and bluetooth/handsfree.
Thanks for using Fixya
Posted on Jul 16, 2008
SOURCE:
My bletooth h350 handsfree device needs a pass code for my phone to accecpt
All the motorola bluetooths that i have had that needed a passcode used "0000". See if that that works. Good luck!
May 28, 2009 | Motorola Mobility H350 Wireless Headset
How to connect nokia 70 with motorola handsfree
is it motorola handsfree headset??
if so...
activate bluetoth of ur nokia cell,
activate the handsfree (pressing long the on off button,for connecting with new device)
1, it automaticaly send the connection request to nokia cell
2 if not, go to paired devices of ur nokia cell blutooth and search more devices.
select motorola handsfree,
enter passcode 0000
it will work.
May 01, 2009 | Motorola Mobility Bluetooth Hands-Free...
Motorola handsfree kit
these kits are not very good and they are old, you are also unable to update software to work with new phones and the mic quality is poor.
go to your paired devices on your phones and change the hf850 to not connect automatically on both the phones, this may work.
If you can get a full refund and only pay the difference for a parrot it will be worth it. Also look at the THB Bury kit.
Dan
Mar 25, 2009 | Motorola Mobility Bluetooth??¢ HF850 Car...
Need a pass key for a motorola h300 in order to pair it with a samsung sphm 540
the pass key is 0000
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
Jan 22, 2009 | Motorola Mobility H300 Wireless Headset
Pass key
pass key 0000
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
repeat step 1.
PAIR
Your Phone
device.
from 0000.
YOUR HEADSET
Jan 13, 2009 | Motorola Mobility H300 Wireless Headset
I can't find my instruction book for the Motorola Headset HS850.
Just google the instructions. Should get a pdf option to download ??
Nov 07, 2017 | Motorola Mobility Universal Wireless...
H350
repeat step 1.
PAIR
Your Phone
device.
from 0000.
YOUR HEADSET
Dec 11, 2008 | Motorola Mobility H300 Wireless Headset
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
I cant scan phones using my bluetooth.
reset your blue tooth , pair it agian with your phone. remove all other blue toohts and pair it again. i hope that works .
Feb 17, 2007 | Motorola Mobility Razor Behind-the-Head...
Lands Phones Logo
114 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
