Question about Canon PowerShot G3 Digital Camera
Canon Power Shot G3 dropped
My husband dropped our camera on a concrete floor; the lens won't retract, the camera won't take pictures, and when I look into the lens, a piece is jarred loose inside. So--sounds serious to me but I'm not sure where to get it repaired. Thank you so much for your help. Sharon
    Genius:
  • 1,447 Answers
Hi-
Go to this link and enter your zip code under service so that you can locate a servicer in your area click HERE
Hope this help! thanks for using Fixya!
Posted on Jul 16, 2008
    Genius:
  • 3,422 Answers
The only way to fix this problem is to get it repaired.Please call canon on the main support no.1 800 828-4040 and they will tell you the nearest service center located in your area
  • Priya darshan Jul 16, 2008
    You can also get it repaired from http://www.advancecamera.com/repair/
    They give:
    • Free estimates.
    • Reasonable rates.
    • Fast, friendly, and personal service.
    • Top quality repairs.
    • Advance Camera 1 Year Warranty.
I dropped the camera. Tripped over the cord, had it plugged in because battery won't hold much charge. Now, lens will not retract, camera buzzes 7x then screen says lens and turns itself off.
Unfortunately the lens has been damaged, the motor and gear linkage is compromised and will require a camera specialist to resolve the issue, I suggest getting an estimate before commitment.
May 03, 2011 | Canon PowerShot G3 Digital Camera
Canon Power Shot A2000 IS lens is stuck in out position. I had to replace batteries. I replaced them and when I turn on, it says "Lens Error, Restart Camera" and it shuts offs automatically.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 05, 2010 | Canon Powershot A2000 IS Digital Camera
Canon A560 dropped.when the cam is on lens wont retract anymore
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
My Sony Cybershot lens is not retracting!!
The lens block needs a replacement and you need a good service center for this job. We can help you in spares supply. Do let me know as this is an expensive spare part. Sonyspares
Jul 31, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Kodak easyshare CX7430
My Kodak camere was really not dropped. I put in new batteries and the camera only gives me one shot and I have to turn it off and try again. I can plug the camera into a charge cord and I can take all the pictures I want. Is it possible the 2 batteries are not enough to power the camera
Mar 28, 2007 | Kodak EasyShare CX7430 Digital Camera
Canon PowerShot G3 Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
