Question about Epson Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
    Genius:
  • 1,447 Answers
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Posted on Jul 16, 2008
In my epson printer the print out come so dirty but the nozzel are ok
Posted on Apr 30, 2011
TimPiggott
  • 3 Answers
SOURCE: there is a document pending
This solution worked perfectly, although I did have to reboot between the run command:
Start>>Run>>net stop spooler>>OK
reboot
Start>>Run>>net start spooler>>OK
Posted on Mar 22, 2009
  • 72 Answers
SOURCE: pending printing
Printers and faxes then highlight printer then go to file and select set default printer. Then open printers and faxes go to file select restart
Posted on Apr 15, 2009
SOURCE: wont let me cancel a pending document
I used to have the same issue. It happened on five different occasions. I tired all kinds of steps to fix it and none worked. Finally, my daughter fixed it for me by accident. She tripped over the plug to the computer. After it restarted, I canceled the document, and it worked perfectly. After that, i knew what to do. Hope this helps@
Posted on Jun 01, 2009
SOURCE: Cant print, pending has no status.
Please check printer cable both end otherwise please replace the data cable.This is the only data cable faulty/ lose connection problem.
Stevenslav
  • 65 Answers
SOURCE: documents keep pending and not printing
You need to either unpause the printer manager or delete all the queue's and restart he computer. Since you have not provided information on the operating system you use, I can not help you further.
Posted on Jun 05, 2009
My HP laser jet M1120 MFP is repors error message when printing
Re install the tonner and then go to Printer & Faxes settings and delete the all kinds of pending documents and the go to print a new document and after taht send me the result...........what is happening.
Oct 01, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Not printing nothing in documents pending
If you are not able to print and all your documents go in documents pending you may want to check the following. Go to printer and scanner setting, right click on printer icon and put away the check on offline printing. Now you should be able to print without problems.
Let me know if you solved the problem
Mar 01, 2011 | Lexmark X6570 InkJet Printer
Pending documents wont print
Your buffer is overwritten. You need to right click on the pending document and select delete it would be easy to delete those processes which are not bufferrred but to delete top document you will have to switch on and off your printer. wait for a minute and restart your computer. You can start printing again.
Mar 18, 2010 | Office Equipment & Supplies
I am trying to print and the computer is saying my documents are pending in the queue how do I print!?
Thants means some pending peinted or pronting documents in que in printer,Please follw the given instructins,,
choose start button
go to setting --> printer and fex option
you see the connected printer,
choose the printer and Right click of the mouse on that icon.
choose open option
you see many pending documents in screen,select all documents and right click of the mouse -->cancel -->Ok
Queue is nil
than you will ready to print.
Thanks
Dec 19, 2009 | Office Equipment & Supplies
I cannot get documents to print. There are 79
open the printer and faxes the double click on the printer driver and cancel the all pending document ....... and check the printer status ......... if is it in ready means only you can take print ......
for any clarification please post your comment ....
Nov 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Document failed to print" message
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Jan 18, 2018 | Dell 1600n All-In-One Laser Printer
Jun 01, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Document pending will not print
Well this could be a number of issues. First of all try to make sure the printer is on, (yes I know very stupid request but I've seen it happen thousands of times). Then make sure the printer is connected to the PC, either via USB or LPT port or whatever the case maybe. Thirdly, you want to make sure that the printer is installed on the PC. If you goto START/PRINTERS & FAXES, and see if there are any other documents that are stuck or pending, try to delete them out or delete the printer and reinstall it. Then try to print again.
Mar 22, 2009 | Office Equipment & Supplies
Printer is pending
the print spooler is not letting it print cancel the pending jobs you will be able to print fine keep on cancelling the documents unless the icon shows 0 document pending ....
Dec 16, 2008 | HP Deskjet D2430 Printer
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Printer Logo
1,125 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
