Question about IBM Wheelwriter 30 Typewriter
Brother3600 typewriter, require mainsjack plug in to typewriter and cable tomains 13amp plug.
    Sergeant:
  • 329 Answers
Can wire directlly to the machine and eliminate the plug. In some states this is against the codes....
Posted on Jul 21, 2008
Can Lamont oven 3201 be plugged in to a 13amp plug?
No, a 30 Amp connection is required because of current load. a 13 amp could not carry the current load.
Sir John Dana Hamilton Taylor
IQ 397
Apr 25, 2017 | Ovens
I've just bought the above phone and connected tomains to charge batteries and handsets show "line chord error" is this because the phone line has yet to be plugged in?
yes, it will either show line cord error, or no line. After phone is charged plug line cord in and it should go away if not check line cord or try another known good cord.
Aug 11, 2015 | Lands Phones
Amperage required to run a 180 amp welder
If you mean the plug rating, you can run a 180amp mig welder on a 13amp plug, however above about 150 amps the fuse in the plug will blow, you then need to up grade to a 16 amp plug and wall socket, with the wall wiring going back to a fuse box with a 20amp fuse.
Jun 16, 2011 | Miller 041969 Secondary Contactor Kit
Not to sure what wire to use and if I can use a plug
You can use it a 13amp plug if it is just a single built in oven and the total wattage does not exceed 3000 watts..
Anymore than 3000 watts, then it will have to be hard wired into a seperate control unit with 6mm twin and earth cable.
Feb 19, 2011 | Belling Ovens
I am going to install my new mytag oven MEW7530WDS01, can you tell me the Amp. protection required for this oven? it is a 220V
If it is just a single oven then a 13amp fuse is all that is required for the oven.
If you are unsure, then check the rating plate.
If the total amperage does not exceed 3kw, then it is safe to use it with a 13amp fuse., Anymore than 3kw, then it should be hard wired, with a minimum 30 amp fuse for protection.
Feb 12, 2011 | Maytag MEW7530WDS Stainless Steel Electric...
At start, led is blinking, but after few\seconds everything stops. No start
Remove your battery and connect tomains power and try again to start! If it starts it's most likely your battery has completely gone dead and requires replacement!
Oct 09, 2010 | ASUS S6F Notebook
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
IBM Wheelwriter 30 Typewriter Logo
22 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
