Need to Switch input on TV with out Remote
Yes... I understand that the sensor is not working on my tv.
Now can you help me with the problem? I need to switch it back from Video input to normal TV.
Thanks
  • 790 Answers
Hi
ok the The TV sensor is bad... you want to replace it? if you want i can teach you how to fix this without labor cost for the technician...
thanks!
Posted on Jul 17, 2008
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
RM-GA014 remote can't switch Sony Bravia 46" tv on
Follow this procedure to troubleshoot if the TV does not respond to the supplied remote control.
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the remote control buttons are jammed.
  4. Install fresh batteries into the remote control. IMPORTANT: Make sure the batteries are inserted in the (+ and -) direction shown inside the battery compartment.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV. IMPORTANT: Some locations can interfere with the IR signal from the remote control. Glass enclosures, as well as fluorescent or halogen lights, may prevent the IR signal from reaching the TV.
  6. Point the remote control at the IR sensor of the TV.
  7. Press the POWER button and other buttons to test TV operation. IMPORTANT: Do not hold down the POWER button too long. Doing so may prevent the remote control from operating the TV.
    NOTES:
    • If some of the remote control buttons operate the TV but others do not, the remote control may need replaced.
    • If all of the remote control buttons work, no further troubleshooting is required. Otherwise, continue troubleshooting below.
  8. Try using the remote control at varying distances from the TV. IMPORTANT: Using the remote control too close or too far away may prevent the IR signal from reaching the TV.
  9. Turn the Light Sensor setting to OFF.
    1. On the TV itself, press the HOME button on the TV.
    2. Using the up arrow or down arrow select Preferences.
    3. Press the INPUT button.
    4. Press the up arrow or down arrow to select ECO.
    5. Press the INPUT button.
    6. Use the up arrow or down arrow to select Light Sensor.
    7. Press the INPUT button.
    8. Press the up arrow or down arrow to select OFF.
    9. Press the INPUT button.
  10. Power reset the TV.
  11. Make sure the TV has the latest system software (firmware) update installed, if applicable.
The troubleshooting steps above should resolve the issue. If you completed all the steps and the issue is not resolved, service may be required or the remote control may need replaced. Contact the Customer Experience Center at (239) 768-7547 to speak with a service representative for further assistance.
Apr 07, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
Can i program lg magic remote to work with direct tv box
If your LG TV came with the IR blaster cable you will need to set one of the sensors in front of the sensor on your DirecTV box. Then go to your TV setting and select Video Input and Select the Input Port that your DirecTV box is hooked to. (In my case HDMI1). Then you will select that you are trying to sync your Service Provider and it will give you a list of device manufacturers. Select DirecTV limited and it will start to give you codes to try. You test these by trying the channel button up or down. If the channel changes you have found your code and you will click on "Yes" and you are ready to control. The "Guide" button will now bring up the DirecTV Guide and you no longer need the DirecTV remote.
Jun 05, 2012 | LG Televison & Video
LG LCD 42 in. HDTV Television remote controller will not work even my universal remote will not work with the tv?? any sugestions as to what it could be?
Look at the back of the TV for the 'EXTERNAL REMOTE INPUT JACK (IR INPUT)'
Insert the mini headphone jack such as the MP3 player headphone jack into this IR jack in and out a couple of times to clean the switch contacts (the switch inside will select the front panel or the rear panel IR input jack signal).
Please try that to see ifit helps. Otherwise it can be the IR receiver board on the front of the TV or the processor in the main board may have failed.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Mar 06, 2011 | LG 42LC2D 42 in. LCD HDTV
Inputs wont work
depending on the model remote and if the remote controls the volume and power, then yes you should be able to..let me know if you need more help or if you have the remote type.
May 04, 2010 | iLO IWT3206 TV
Hi -- I have a Logitech Harmony 676.We installed a new component ( a Bluray player ), and had to create a new account. So we went through all the steps, and now we can't get any sound. Also, the TV doesn't...
First you need to figure out why your not getting sound. For the following don't use the remote. Turn everything on manually. Set the TV's input to the source you want i.e. DVD, input1, inuput2, etc... While viewing that source manually turn up the volume on the TV or receiver. If using the receiver, toggle thru the inputs untill you here your program. Write down the combination of equipment and there input settings. Bottom line we need to get your hardware working and understand the settings before we start working on the remote. Once the hardware is working you can then program the Harmony with the correct settings. If your hardware is not getting you audio please send me more information concerning your setup. TV type, Cable box, direcTV Reciver. I need to understand your setup before I can help you troubleshoot your system.
Hope this helps.
Jan 27, 2010 | Logitech Harmony One Advanced Universal...
How do I replace the IR remote sensor on my LG TV?
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
Jul 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Abilities of Universal Remotes
Yes!
When you define different activities (such as Watch TV, Watch DVD, etc.) the remote will ask which of the TV inputs your device is plugged into.  After programming, when you select the appropriate activity, the remote will automatically select the correct input.
Jan 02, 2009 | Logitech Harmony 890 LCD Remote Control
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
Electro Med Services...
