Question about Philips CD1503B/17 Phone
Searching Phone not receiving,sending or ringing. Display says "Searching"
  • johnjop Nov 01, 2008
    Same make, different model maybe.
    Exactly the same problem, Phone not receiving,sending or ringing. Display says "Searching"
  • andrea5150 Jan 02, 2009
    Phone says searching can't dial out or recieve calls. It does NOT matter what location of the house the phone is in. Is it possible digital phones won't work in all areas?
    Problem Solver:
  • 19 Answers
You have a problem on the signal of your phone find a good location
Posted on Jul 16, 2008
HaveBinatone Symphony 3325 triple. screen shows 1 new call. cannot listen to call or clear it cannot receive or send calls. can you find me the instructions to clear this please
Showing 1 New Call would mean you need to check the Caller Display Record by pressing the arrow pointing up marked "Calls". This is not related to not being able to make/receive calls. If the phone is ringing and displaying "Handset 1" then check line, if it says "searching" then you will need to register handset. Call 0845 345 9677 for more help.
Feb 24, 2011 | Cell Phones
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
Everything works fine except receiving a fax.
Check the answer mode, you should easily be able to see it in the display when in idle mode.
The CD is not needed for the machine to perform actions not requiring a computer, e.g. sending/recieving faxes.
Also, check the phone cable connection so that it's connected to the LINE outlet, and not the EXT one. Connecting it to the wrong contact would still make the machine ring (as it detects the "call" on the line) but unable to lift the call since the modem communicates only through the LINE port.
You could troubleshoot by letting the machine be alone on the line to see if it can send and/or recieve faxes.
Jun 03, 2009 | Brother MFC 420CN All-In-One InkJet...
Kyocera candid ii will not send/receive calls.
you have to deactivate your call divert service for all
May 19, 2009 | Kyocera Candid KX16 Cellular Phone
How can you send a ring tone or sound to another phone from razrv3a?
Hi Motorola tends to do Bluetooth sending differently. Make sure your receiving phone is set to discoverable and B/Tooth ON. On the Motorola turn on B/tooth and find file you want to send. With the file highlighted press option and you should find 'move to' and 'copy to'. If you select move to, it will send file to receiving phone, but remove itself from the Motorola! Best to use 'copy to'. If the Motorola cannot find the receiving phone once searching, to send the file you may have to pair the two devices first. To do this it is best to go into Motorola's B/tooth menu and set it to 'discoverable' this will stay active for a few minutes. Then on the receiving phone search for new devices in B/tooth menu. It should find the Motorola and request a four digit pin which default on most phones is '0000' if this fails try '1234' (it will be one of those, more likely first one). Once both paired try sending file again and it should work. Let us know how you get on?
Apr 23, 2009 | Motorola Mobility RAZR V3a Cellular Phone
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
HP640 not receiving with Distinctive Ring Option
You need a dedicated ANALOG phone line.
A DSL filter screens out ANALOG signals to a DSL device.not the other way around. There are no DIGITAL fax machines.
Aug 10, 2008 | HP 640 Inkjet Fax Machine
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan(sajwhat_2003@yahoo.com)
May 03, 2008 | Nokia 6600
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Philips CD1503B/17 Phone Logo
310 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
