Question about Pioneer Audio Players & Recorders
The power swich wont let it out of standby and the cd player wont work
  • 2,071 Answers
Pull the plug from the wall outlet,and wait for one hour and plug again,it's like you reboot the system,problem like this ,your player needs to clean,this is symptom of dirt and hardened grease in the rail chrome bars.The slider mechanism, depending on the age of the unit and consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. if i helped,please click fixya,it is the only way i get paid for my works...
Posted on Jul 18, 2008
Tdk cd player stereo system stuck on standby. the red standby light is on the only thing I have done since it was last working yester day is remove and reinsert the speakers from the unit.
Try resetting by leaving disconnected completely from the mains for 2mins. Throughout this time frame keep your finger pressed on the power/standby button.
Feb 18, 2016 | TDK Audio Players & Recorders
Ps3 40gb fan test fail
you over heated it thats a temp fix it wont work again
Jan 25, 2012 | Video Game Consoles & Games
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
Cd player wont let me put the code in , on a vauxhall omega , it says safe when swiched on but wont change so i can input the code
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself (This could be several hours )
Apr 01, 2010 | Car Audio & Video
Kenwood kdc mp336ax cannot get aux.to work or show on display ,only c.d, tuner,standby.so my mp3 player wont operate.any clues???
go to standby and hold the menu button. use fm and am to navigate until you see aux1 off. turn it on with the forward button then you are done.
Apr 14, 2009 | Kenwood KDC-322 CD Player
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Wont turn on
No, most units will at least work basic functions without a remote. What is the make / model? I would take it back as soon as you can.
Jan 19, 2008 | Audio Players & Recorders
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
44 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
