Question about HP Office Equipment & Supplies
Need complete set up guide again lost leaflet and cannot get printer to print off laptop need help tosetup again please.
  • rebeccaisaac Jul 16, 2008
    sorry how stupid of me its a hp f300 all-in-one series printer.
  • HP Master
  • 691 Answers
Maybe you could the world a clue by telling us what printer you have and what computer you have.
Jeez lady - we are technicians not clairvoyants :-(
Posted on Jul 16, 2008
  • Inky Fingers
    Inky Fingers Jul 16, 2008
    The HP web site has the information you need. The following URL will take you to the set up document for an F325. As you have not given the specific model, only the series, this is about as close as i can get.
    HP WEB SITE
How do i set up voice mail on NEC DTU 16D 2?
You need a laptop hooked up to the vmail system and or do via from telephone form system mangers mailbox.
You should be calling your vendor who handles the system, this is complex and involves passwords and which mailbox was assigned SM etc.
They vendor can also supply you with guides.
Dec 06, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
Using Lex. 4'x6" paper, my 901 is not
To properly lay the 4 X 6 in paper in the tray, please follow the steps below:
  • Pull tray completely out of the printer.
  • Move the paper guides to the sides of tray.
  • Use the photo paper outline on the bottom of the tray to help you position your paper.
  • Load your paper.
  • Adjust the paper guides to rest gently against the left, right, and bottom edges of the photo paper.
  • Insert the tray.
Make sure the correct print setting is configured before printing your file. With your file open, click File > Print > Properties > From the Paper Size list of the Print Setup tab, select 4 X 6 in. Click OK to save the setting. Click OK again to print your file.
Jul 24, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have lost instruction leaflet and do not know how to operate printer
1. Using a printer even basic printer is extremely easy to do. There are many different models of printers out there. You have your very basic to your all-in-one printer. The printer with everything on it works pretty much just like the regular printer you just have a lot more buttons to push.
2. Make sure that your printer is hooked up properly before using it. If this is a brand new printer then it will go through a check and print out a test page for you. A lot of different times you can just turn it on, you will hear the ink moving around. Something might come up on the computer telling you that the printer is on and working properly.
3. Open the page you want to print. If you are on the Internet and want to print something from there. All you have to do is go up to file, then down to page set up. This will give you more printing options to choose from. When you are done setting up the page you can verify you have the right printer hooked up by clicking on "Printer" at the bottom. Once everything looks good click on "OK" and now your page should print out.
4. Open up a ".doc" file if that is where your page is that you need to print. When you are ready to print go up to "File" and "Print Setup". Again you can choose how you want your page to look, and check and make sure the right printer is installed. If your page is set up the way you like it you can just click on the printer icon on the tool bar or go to "File" then "Print."
5. Using a printer a lot over time will start to wear down your ink supply. Some models of printers let you know when your ink supply is getting low. If you have an older printer you will just have to go by what the printed page looks like. If it is very worn and faded then it is time to install a new ink cartridge.
Printer Help
Nov 11, 2010 | Office Equipment & Supplies
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Mar 02, 2009 | Brother MFC 6490CW InkJet Printer
Lost user guide for spp202
For a quick guide and/or the complete manual pls go here. The User Manual is in pdf. You would need Adobe Acrobat to view and/or print this manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 21, 2008 | Samsung SPP-2020 Thermal Photo Printer
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Hp deskjet f4180 all in one
i have a hp deskjet f4185 all in one printer but i lost the cd. i need the sofware or it will not connect to print or scan please help me where can i get the sofware?
Feb 15, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
