Question about Kitchen Ranges
Broken glass on oven door for model GJP84802, and don't know how to replace it. Jay
  • Anonymous Sep 26, 2008
    I did a self clean the other day, and the inner glass broke.
I have the complete answer with step by step instructions and detailed exploded-view drawings with labelled part numbers. Since you won't give me any answers without charging me $3, if you want my solution, you'll have to send me $3. I think that's fair since you'll just turn around and sell my solution over and over for $3 per person./
Posted on Sep 28, 2008
Need to know correct size of microwave door glass for LG model MG-604w mine is broken after a fall, can I still use without glass?
NO, do not use the microwave with a broken door glass, this glass is specially protected to stop any dangerous microwave leakage, it is also something you cannot replace yourself, take it to a reputable service centre so that once the glass has been repaire the oven can be tested for safety purposes.
Sep 09, 2013 | LG Over-the-Range Microwave
Glass door to bottom oven has broken. Looking where to find replacement glass. Its black/smoke colored.
Not enough information.
Will need to know the model number and product number.Then repost your question.
Hope this helps.
May 20, 2010 | Ovens
Roper microwave has broken glass in the door
Whatever you do don't use the microwave until you replace the door. You run the risk of possibly shattering the glass or being exposed to dangerous microwaves from the oven. Get on the Roper web site and find a replacement for the door. You never know there could be a recall for safety issues on your particular model.
May 02, 2010 | Microwave Ovens
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
Broken handle on Spacemaker microwave
The handle can be replaced without replacing the entire door, or oven. The part number is WB15X1309 and can be purchased at pcappliancerepair.com for about $45. Due to the age of your oven, I could only find it at a couple of web sites, and this was the cheapest price I could find for you.
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 08, 2009 | KitchenAid KHMS147 Microwave Oven
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Jan 01, 2009 | Zanussi ZBQ365 Electric Single Oven
Kitchen Ranges Logo
403 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
