Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Transmission Oil reservoir
2004 Fatboy, 32,000 miles.
Is the primary and transmission sharing the same oil ??
Or is it separate. I just drained and chnged the Transmission oil, and this morning my primary is leaking a that because I over filled the Transmission oil. It says it takes 1 qt. and that's what I put primary hadn't been leaking previously.
I figure to split the primary, clean it up and replace the gasket.....should I now drain the the Transmission oil again to do this ?
  • Anonymous Jul 17, 2008
    I have a 2003 Deuce with a similar problem. While changing the oil, I found that the primary case had accumulated and excessive amount of oil. Can oil serviced to the transimisson bleed into the primary case???
  • Anonymous Mar 29, 2014
    i added oil to my gear box and adjusted my clutch adjusting screw a 1/4 turn it was fine for about a 1/4 mile then i hear a whining then a little grinding sound
    Problem Solver:
  • 8 Answers
The trans. and primary are seperate.
Posted on Jul 17, 2008
What are different types of oil drain plugs on Harley FatBoy
There are three, engine oil, transmission oil and primary oil, all are 5/8 inch hex plugs and use o-rings to seal.
Jun 06, 2014 | 2001 Harley Davidson FXD Dyna Super Glide
Where's the oil drain plug for 2010 low fatboy harley
Which of the three drain plugs. Primary is on primary case below derby cover; transmission is on right side middle bottom of transmission, engine is at bottom of right rear frame down tube intermediately forward of rear tire. ALL are 5/8 inch hex plugs with 1/4 inch Allen socket in the middle of the plug.
Apr 13, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
Why does gears 1 and 5 work normal but 2 thru 4 has a grinding metal sound? sounds pretty bad.Does the trans. have a separate oil resevoir? 2004 883 sportster
Yes the primary case-transmission require it's own oil as the lubricant for this area is not provided by the engine oil. There is a drain plug located at the lower point of the case. Remove the plug and drain any oil that may be in the primary case. When finished, add one quart of oil to the case through the access hole at the top of the primary case where you check the tension on the primary chain.
Good Luck
Aug 01, 2011 | 2004 Harley Davidson XL 883 Sportster
How many oil drain plugs on a 2001 FXD and what other fluids should be changed when doing an oil change?
I'm not a Twin Cam mechanic but I think there are two oil drains on the bottom of the transmission. The oil tank for your bike is on the bottom of the transmission. It looks like there is a drain on the bottom of the pan and one on the front. The oil should be changed every 3000 miles if you're using petroleum based oil. Synthetic oil can go a bit longer. The primary oil and transmission oil should be changed every 5000 miles or so. The primary drains from a pipe plug underneath the primary back near the rear of gearcase. The transmission drains from a plug underneath.
Good Luck
Jun 28, 2011 | 2001 Harley Davidson FXD Dyna Super Glide
I have a 2004 xl883 converted to 1200 need to change the fluids. does the transmission and the primary use the motor oil that you are putting in bike or is it differant. and when you drain oil and...
You engine uses three quarts of 20W50 oil. The primary and transmission share the same oil and it uses about a quart of oil. One the late model Big Twins, you can use H-D's Syn 3 in all areas. Not sure about the Sportster. I've always used the H-D primary/transmission lubricant for Sportsters. If you wish to use any other brand of lubricant, you need to go to their website and check to see what they say use in what area. Some of the other popular lubricants are Amsoil, Royal Purple, Mobil V-Twin, and Red Line.
Good Luck
Jun 26, 2011 | Harley Davidson XL Sportster 883...
Looking for the oil drain plug and the transmission drain plug on a 2001 Harley Davidson XL 1200 Custom
Usually the oil drain is one the left side of the bike somewhere below the battery. Look for a hose that has a plug in it or one that connects to the frame. Harley had moved this drain so many times in the past that it's difficult to keep up with where the oil drain is located. The transmission and primary share the same oil. To drain it, find the drain plug on the bottom of the primary just below the clutch. Pour the new oil in the primary chain inspection hole of the primary.
Good Luck
Jun 12, 2011 | 2001 Harley Davidson XL 1200 C Sportster...
Need assistance on changing oil and primary. Warrenty is out and doing it myself.
The oil drain plug is on the bottom of the transmission as the oil tank is located there. Usually the drain plug is the one closest to the left front of the pan. Drain the oil, change the filter, and add fresh oil. To change the primary, locate the small pipe plug on the bottom of the primary directly below the derby cover and remove it. Drain the oil, remove the derby cover, and stand the bike straight up. Fill the primary with oil just until it comes up the bottom of the outer clutch drum. Do not overfill. To change the transmission lubricant, locate the pipe plug on the front of the oil pan on the bottom of the transmission. Drain the oil and refill though the plug and dipstick in the chrome release cover on the right side of the transmission. Add 20-24 ounces of oil.
Good luck
Jun 05, 2011 | 2004 Harley Davidson FLHRCI Road King...
Where is the oil drain and how do you refill tranie fluid
The oil drain on your Sportster should be on left side of the bike below the battery around the rear of the primary case. It'll be a short piece of hose with a metal plug in it or a hose that appears to plug onto the frame. Simple pull the plug or take the hose loose and the oil tank will drain.
On the transmission, you remove the top inspection cover of the primary case to add the oil to it. The primary and the transmission share the same oil.
Good Luck
Apr 25, 2011 | 2004 Harley Davidson XL 883C Sportster...
I,ve got a 2008 Ultra classic, and want to change the fluids. It's got 8000 miles, and i dont have a owners manual. the oil, i can figure out , but the trans, and the primary I dont have an idea.
On the bottom of your transmission, there are two drain plugs, one for the transmission and one for the engine oil. The plug in the center is the transmission drain plug and the one toward the left front is the engine oil drain. The primary drain is a small pipe plug that takes a Torx wrench located at the bottom of the primary cover towards the rear of the bike.
Engine oil three quarts with filter. Then start the bike and let it run for a few minutes. Shut down the engine and check the oil level with the dipstick. The dipstick has two marks on it. "Full Cold" and "Full Hot". Fill to the full cold mark.
Transmission takes 20-24 ounces of oil and the primary takes 38-44 ounces of oil. Do not overfill the primary as it will cause your clutch to drag. All three sections take H-D Syn3 20W50 synthetic engine oil.
May 23, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
Where is the oil drain plug on 2007 Heritage Softtail Classic and how to change oil?
Look at the bottom of the oil tank from the right side of the bike. You'll see one hose or pipe that goes downwards towards the back of the transmission. The hose will follow the frame and come out way down low on the backside of and slightly under the transmission. There is a plug in the hose or pipe. Take the plug out and the oil tank will drain.
To change the oil, drain the tank, change the oil filter, refill with three quarts of oil in the tank. You also have oil in your primary that should be changed every 5000 miles or so, and the transmission serviced at the same interval as the primary.
To drain the oil on the primary, there is a drain plug under the primary case at the very rear of the case. Remove this to drain the case. Refill the primary through the derby cover. Fill with oil until the level is just to the bottom edge of the clutch spring. 38-42 ounces of oil. Do not overfill or the clutch will drag and make finding neutral with the engine running impossible to find.
To drain the transmission, there is a small plug on the bottom side of the chrome cover on the right side of the transmission. Remove the plug, drain the tranny, and refill through the large plug that takes a hex key in the chrome cover. 20-24 ounces of transmission lube.
Good Luck
Apr 01, 2010 | 2005 Harley Davidson FLSTC - FLSTCI...
Lands Phones Logo
345 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
