Check this website you find there fuse box diagram and description for Lexus GS300 (1993 - 1995)
Lexus GS300 1993 1995 fuse box diagram Auto Genius
SOURCE: lexus gs300
inside the gas tank. remove the gas tank and its right on top. remove all 3 screws and turn and pull out.
SOURCE: Replacement brake pads for 06 Lexus GS 300?
go with standard pads.they wear a little faster than ceramics.but they dont wear down brake rotors.ceramics pads are hard and they cause brakes to squeak.also your car is under warranty with lexus dealership.i would use what they said. because you have future brake problem. they will void out warranty for not using their brakes.
SOURCE: how to change rear brake pads on 06 Lexus GS 300
Rear brakes similar to fronts except that caliper piston must be screwed back instead of compressed (due to use of parking brake).
SOURCE: lexus gs300 dash lights ,sunroof,gear lever,windows, not working
hello freddy - the good news is that your lexus has a self diagnosis system built into it. this is what you need to do.
drive to an auto zone or similar autoparts store and have them put your lexus on their computer to scan for trouble codes. they offer this as a free service. with a little luck this scan will isolate the problem and the fix will be quick and easy.
if this doesnt fix it for you get back and let me know what codes popped up.
here is a link to the lexus trouble codes so you will have added insight. good luck.
http://www.troublecodes.net/Lexus/
SOURCE: how to get the vsc off my 2000 gs 300 lexus
there is a switch under the dash to turn the vsc on and off. its on the driver side
