Toshiba studio 35
I need to rest the pm counter for my toshiba studio 35 copier, how do i go about it?
  • Anonymous Mar 13, 2014
    my toshiba e-studio 18 counter is not working
Switch off copier first,Then
Swith ON copier while holding 0,8 numbre buttons
Then screen is displayed " TEST MODE"
Then enter 252 numbre and press Print button
Then copier displayed PM counter
Then enter "0" button Then press ENTER button on Display
Then Switch OFF and On normally
And Continue your Job.
Posted on Jul 25, 2008
    Problem Solver:
  • 6 Answers
Switch off...hold down 0 + 8 keys,
switch on holding keys for 5-10 secs then let go.
service mode...
punch in 251 then print key should show pm set figure,punch in say / add 20,000 on to figure then press set in the display.
switch off then on should have cancelled prevent maintenance.
Posted on Jul 17, 2008
Toshiba studio 2006 how is rest maintenance code
turn the power ON while pressing [0] + [8] then 6194 (Current value of PM counter Display) to "0".
Oct 16, 2016 | Toshiba Office Equipment & Supplies
How to reset pm counter toshiba es 356
Power "OFF" the copier. Press continously "0" and "8" while turning on the power. From the screen it will show AD mode. Press "252" then "Start". It will show some numeric values on the screen, " this is the past PM count ". Press "0" then "Start" or "Interrupt " key then power off and on the copier ..
Nov 04, 2014 | Toshiba E-Studio 356 Multifunction Copier
Toshiba e-studio 18 toner empty clear message procedure
1-800-Go-Toshiba
http://business.toshiba.com/usa/support/index.jsp
  • Phone Number
    800-457-7777
  • Talk to a Human
  • Call Time
    Average Wait: 14 mins - Mon-Fri: 8 am - 8 pm CST
Apr 16, 2014 | Toshiba e-Studio 35 Copier
How to reset maintnance counter
Enter 08-252, clear the value to "0".
08-251, set the value of PM counter.
Jun 25, 2012 | Toshiba E-Studio 202S Digital Copier
I have an estudio 350 that I need to reset after a "time periodic maintenance". How do I reset?
THIS MESSAGE APPEAR BECAUSE THE PM COUNTER IS THE SAME OR LESS THAN THE COUNTER OF PM'S UNITS (YOU CAN SEE THIS COUNTER ON THE 08 252).
YOU HAVE TO DO THE PM TO MACHINE. HOWEVER YOU CAN DO THIS STEPS TOO:
1.- TURNS ON THE COPIER HOLDING 08 KEYS
2.- ENTER 251 CODE AND PRESS START KEY
3.- ERASES THE NUMBER THAT SHOW AND PUT 0
Dec 09, 2010 | Toshiba e-Studio 350 Copier
Need service codes for this model
By default, after 74000 of PM counter, it will appear.
U can clear it if the machine is working fine.
Reset PM counter
08-252, set the value to '0'
To disable the PM counter,
08-212, set the value to '0'
May 06, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Dec 15, 2008 | Toshiba e-Studio 35 Copier
Cannot get the machine out of PM Maintenance mode
to reset PM counter : Hold down 0+8 together, turn on power switch, enter number (252), press (0) key, press ( enter) on screen, Shut down then turn machine on again.
Jul 10, 2008 | Toshiba e-Studio 350 Copier
Thoshiba E studio giving the Total Counter 220320 number and display call for service. You are requested to advise.
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
Nov 16, 2007 | Toshiba e-Studio 350 Copier
254 people viewed this question
jasbo
jasbo
