Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge making "knocking" noise
GE Artctica makes "knocking" sound every 3 to 5 minutes. How do you get the "roof" housing, under the light on the refrierator side, off? My husband thinks he can locate the problem but doesn't want to break the plastic trying to get if off.
  • 2 more comments
  • mohrbeer Dec 19, 2008
    same issue. New fridge, knocking every 5-10 minutes or so, off and on. Very annoying and somewhat loud. It's like someone is knocking on my door rat a tat tat. HELP
  • sharim136 Dec 19, 2008
    Sounds like we all got the same lemon. Thee fan in the freezer turns on and off in rapid cycle (like every 3 seconds) and then I turn off the fan to the freezer, I get that knocking noise fora few seconds. Today it kept knocking for a minute or so after shutting off the freezer! Sounds like an old Chevy I had that kept running after the ignition was turned off.
    This fridge was recommended by Consumer Reports! What a joke.
  • tombarber Feb 13, 2009
    Loud knocking sound seems to come from back of fridge side in 7-year old Arctica side-by-side. Happens every 5-10 minutes.
  • mikecarnatha May 11, 2010
    I'm having a knocking sound on my GE and have no idea where to start. It sounds like it is coming fron the top of the fridge. please help it is driving my 8 month prego wife insane. God Bless Mike
  • 54 Answers
Remove the light shield and there should be screws under it. Remove the air tower in the back, it snaps in and there is 2 screws behind that as well to remove the damper housing that sits behind the light. Also not sure what your model is but some models have 2 air ducts that run up each side, they come out after the light shield is removed by sliding foward and then pulling down. After the screws are removed in the upper plate the light assy will snap out and there is 2 quick disconnects on the wires.
Posted on Jul 16, 2008
Kitcheaid side-by=side started making knocking noise. I discovered it to be the water line to fridge (for ice & water dispenser). It was actually shaking and hitting fridge and wall. It would do this even after unplugging the fridge. After some sleuthing, I discovered it was a leaking toilet in master bedroom. Once that was fixed, the knocking stopped. Now whenever water is turned on and off anywhere in the house, I can hear the water line hit the back of the fridge. Now I just need to tape it down better.
Posted on Jan 08, 2010
Knocking noise
check the sprocket sometimes they are put together with screws and it might be extruding out and rubbing.
Mar 04, 2014 | Yowza Fitness CAPTIVA - Worlds 1st...
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
It started making a repetitive knocking noise, that stops and starts again every couple of minutes. But seems to be working.
Mine does it too... it's your motor at the back of the fridge that opens the vents that needs changing
Aug 07, 2009 | GE Refrigerators
GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Noises when starting up
If you have it, the owners manual will describe what strange sounds it makes. It sort of sounds like normal popping that the system makes when the refrigerant flashes to a gas in the evaporator section. This sometimes happens with age and is fairly normal. If that's what it is there's no cause for alarm. I can't think of anything else that would make the noise you describe.
Feb 20, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
3,954 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
