posted by ritas on Jul 16, 2008
MY GATEWAY LAPTOP WILL NOT CHARGE OR EVEN COME ON.
IT SEEMS AS IF I NEED A NEW BATTERY IS THERE A WAY TO TEST BEFORE I BUY A BATTERY AND IT NOT BE THAT. I HAVE IT CHARGING BUT IT WON'T EVEN TURN ON.
Best Solution
posted on Jul 16, 2008
Make sure your charger is still working,if so then if the battery continues not to charge,your battery is bad,you need to get a new one.
Rating Locked! (?) ritas has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for System Power Supplies
Email this problem
Email this problem
This Problem Also Relates To:
GE (515PS1) Power Supply
HP (152769-001) (152769001) 250-Watt Power Supply
HP 415-Watt Power Supply
HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply
HP (51842191B) Power Supply
HP (AE495A) Power Supply
HP (351599-001) (351599001) 460-Watt Power Supply
Can you Help with these System Power Supplies problems?
Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Constant Beeping
Constant Beeping
Hi Of recent my power supply... Answer This...
Acer (91.AB814.003) 450-Watt Power Supply
SMPS powered on but the display...
I repair an SMPS and its all... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
