Question about Samsung HT-Z210T Theater System
My samsung ht-tz225 is showing disc error when i try playing dvd's yet it plays cd's
5 Suggested Answers
SOURCE:
SOURCE: my samsung home cinema ht-tz212 wont play discs,
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Posted on Apr 10, 2010
SOURCE: Hello I have a Samsung HT-HTX22 home cinema.
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Posted on Jul 24, 2009
hawk127311
  • 350 Answers
SOURCE: i cant play any discs on my samsung ht x200 due to
Go through the set up menu on the Ht DVD player (if it's all in one) and change your settings for the region code. Obviously it is not the one that you have already set it to (probably set by manufacturer). NTSC, PAL, etc. I hope this helps.
Posted on Oct 26, 2009
  • 308 Answers
SOURCE: my samsung HT TQ22 dvd player doesn't play
Take the top case off the unit, power on, and place a dvd into disc tray. Press the play button and see what happens. It should find the dvd, clamp it in the reader and then spin it at high speed. If it does this and still says disc error, then the read head is bad. If it does not spin at high speed, then the epindle motor is bad. This is the more common error with Samsungs. Repair shop time.
Posted on Mar 10, 2010
HT Z210 is not working. it usually says disc error or no disc. i often push the function button and put it back to dvd/cd in order for it to play.. usually takes 3 mins. to play..
the pick up lens is dirty you need to clean it manually by removing the cover.use a cotton buds moistened with an alcohol gently wipe it on the lens then try again
Aug 11, 2011 | Samsung HT-Z210T Theater System
Samsung HT-TZ225 Home Cinema System Ok the speakers are fine but the dvd player is selecting which discs it plays and makes a whirring noise when switched on..I have bought a lense cleaner but it hasn`t...
the fault is from the lens. The lens is weak such that a lens cleaner cannot revive it to its former state.
If the player is still under warranty, it would be better for you to return it.
But if its not under warranty, then you will have to change the lens completely, to a brand new one. By so doing, the player will play all discs.
You need a more active lens for your player to play all discs.
Good luck.
Apr 22, 2010 | Audio Players & Recorders
My samsung HT TQ22 dvd player doesn't play dvd's."DISC ERROR" appears each time I try to watch a movie. Any info on how to fix this problem would be greatly appreciated.
Mar 09, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
I Listen to my xbox or regular tv/sky through my samsung HT-TZ225
your xbox wire is three white red or yellow tv also three option to w r y to put in theas to play
Oct 06, 2009 | Samsung HT-X40 System
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
Samsung dvd home cinema system ht-ds110 not playing dvds
My initial IDM-1731 tells me no disc every time i try to play dvd cd please help me
Jan 06, 2008 | Televison & Video
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
Samsung HT-Z210T Theater System Logo
256 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
