Question about Cameras
When inserting a transcend 4GB card the camera shows "card error" when i then try to format it the camera locks and will not do anything including switching off. What is wrong and what do i do R L Stynes The camera is a vivitar vivicac x345
  • rlstynes Jul 16, 2008
    I'll Check it out first
  • 790 Answers
Hi
maybe this is not compatible to your unit the 4gb.
Posted on Jul 16, 2008
    Genius:
  • 3,422 Answers
HI,
try to use memory card to other device like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error message, camera needs service.
  • 1 more comment
  • Priya darshan Jul 16, 2008
    Also see in the specification details of your camera what memory card is compatible for camera.
    Please reformat you card once in the card reader slot of your PC/laptop and then use it on your camera.
    If you need anymore help let me know..
    Goodluck..
    Can you please tell me whose solution was most helpful?
My 4gb memory card showing 30.1mb and can't formatted
My 4gb memory card SD showing 30.1mb and can't formatted it{Transcend}
Jul 23, 2014 | Transcend TS4GSDHC6V 4GB Micro SDHC Flash...
My Kodak EasyShare V530, won't accept a memory card, you insert a memory card, and it doesn't even acknowledge that there is a memory card inserted.
I bet the memory card that you're inserting is a brand new 4GB SDHC card (your camera can only use 2GB or less standard SD cards). There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Apr 10, 2011 | Kodak EasyShare V530 Digital Camera
Both memory cards show "THIS
Are both cards 4GB or larger SDHC cards, and is your camera more than a few years old? There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 29, 2010 | Cameras
My cannon a 530 says that it has a memmory card error, and it shows memmory card locked momentarally at bottom of screen, i tried to unlock with the slide on the card itself, but that did not help. i put a...
No that's not likely the problem. The new card is probably the issue, especially if it is 4GB or higher. There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 28, 2010 | Canon PowerShot A530 Digital Camera
I have a Conon Powershot S1 IS camera and bought a Transcend Compact Flash 4GB memory card and when I insert in into the camera a red light flashes at the menu and set buttons?
Have your new memory card inserted into your PC to test for any virus. Format the memory car.
Please check if your cannon is adaptive to the 4GB (check the instruction manual) if the card shows the same fault now after inserting.
Use another card into the camera to confirm if the card slot is faulty.
Sep 13, 2010 | Canon PowerShot S1 IS Digital Camera
After inserted A new batteries in the screen shows card locked how I can fix that
May 15, 2010 | Canon Powershot SX110 IS Digital Camera...
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
