Question about Motorola Mobility RAZR V3
It freezes up!
When i first got the phone it worked fine it just needed to be fully charged so i charged it all the way and was having fun with my new phone..Then it started freezing up in the middle of text messages. Not knowing whats wrong i was pushing buttons and the side button got it going again but only for two seconds..now it works every once and awhile..ive tried taking the battery out restarting or just turning it off but nothing works it just keeps freezing or scrolling or doing whatever it wants..i really like this phone and i just want to know what the heck is wrong with it! Please help!!
  • bad_betty_to Jul 16, 2008
    The phone turns on, connects to network, but won't let you do anything. No buttons work. It will tell you if you miss a call.
    Scholar:
  • 87 Answers
If playing with the buttons gets it to work off and on, it is most likely that there is a bit of moisture in one of the side switches. If you press and hold one button continually, it will disable all other buttons (freeze the phone) or if there is some corrosion in the contacts, it could be shorting out (acting like repeated button pushing). You can disassemble the phone, unplug everything. Remove the switches (white sticker with metal domes on the underside.) look for any corrosion, or moisture evidence, even on the side switches. Use 91% rubbing alcohol and a toothbrush to clean the main board and any connections. Use a small flat screwdriver or metal paperclip to gently scratch the under side of any of the metal domes if there is evidence of corossion or scorch marks. Use a pencil eraser to clean the switch contact surface on the main board if there is any evidence of corrosion or scorch marks. DO NOT SCRATCH THE MAIN BOARD. Use the gently scratching for the underside of the switches only. You should be able to get into the phone with a T6 Torx screwdriver. Found at almost any hardware shop or online.
Posted on Aug 21, 2008
    Brigadier General:
  • 7,752 Answers
Take the phone and have the firmware reflash on the phone
Xperia arc LT15i wont turn on
the charging pin of ur phone is not working properly ..... take it to the service statio they will fix the problem
Nov 06, 2013 | Sony Ericsson Xperia Arc
My cell phone battery dies much quickly
Some cell phone batteries work fine for a short period of time and then rapidly diminish their holding capacity. The battery that has previously worked fine for 10 days standby begins a downward time drop to last merely a couple of days. A simple procedure that I have found to be invaluable is to:
1. Turn the power to the phone off.
2. Remove the battery from the phone.
3. Replace the battery into the phone.
4. Fully charge the battery.
5. Test the results by noting the time and day of item 4 above. Leave the phone on standby and see if the charge will now last many days. If so, congratulations, your phone is almost as good as new, and you didn't need to find and buy a new battery (or bother the customer service staff).
Feb 05, 2012 | Sharp Cell Phones
Phone will not turn on and is as good as dead. It has not been damaged in any way, the battery is fully charged. It was working fine yesterday
no.the battery its not fully charged
the battery got dead.yo need to relife it.by sending it to a mobile repaire store.
or buy a new battery
May 08, 2011 | Cell Phones
My sgh-j700 is freeze up on me. what is the problem and solution
Well, ask yourself some questions 1:have you got your phone went 2: do has your phone ever dropped on the ground, if so you have to get a new phone. At my current 13 year old knowledge i say the wires are crossed with each other freezing your phone,my friend had the same problem with his Rumor 2. What my friend did was took the battery out,put it back in,then he charged it and it worked fine...or so it seemed. Hm what i'm trying to say is you might need to get a new phone.
Dec 16, 2009 | Samsung J700 Cellular Phone
Phone freeze
first try the phone using another battery, do tyr changing the unit battery make it sure it was fully charged. iy seems that you have a weak or faulty battery pack now.
Hope this initial info/idea helps
May 30, 2009 | Samsung Cell Phones
Top row of buttons don't work
Well, I found the solution. I traded batteries from one the working handset to the non-working one, and the problem was corrected. Thus I need a new battery.
Jan 15, 2009 | Panasonic KX-TG5632 Phone
Freezing
That happens to mine, too. What you do is stick a pin through the little reset hole on the left side (under the switch you hold down to turn it on). That should reset the player. If that doesn't work wait until the battery runs out and then charge it.
Aug 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Fun mode and batteries
Dont use Ni-cd batteries, only NiMH or the new "Oxy" batteries from Panasonic, 5X the power of Alkaline and higher voltage, GREAT disposable battery for a Digi-cam. Some cams will NOT work on the old zinc batteries, even brand new. Fun mode is probably just to edit anyway, probably not a shooting mode.
Feb 25, 2008 | Samsung Digimax S630 Digital Camera
Cant use ps3 controller wirelessly
it sounds like it has been droped you will have to get it looked at it could be a lose battery conneion or lose wire
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
