Question about Sub-Zero Refrigerators
Sub zero 611 flashing service and error codes 05 EC & 21 EC
SOURCE: sub zero 650-display
If you cleaned out the condensor unit, your problem is probably a bad evaporator. Schedule a service call. If the condensor was really dirty then you may have just compacted the dust into the condensor in which case a shot of CO2 would be a good idea.
Posted on Oct 07, 2008
SOURCE: Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Posted on Jan 03, 2010
SOURCE: Sub Zero 650 Refer with a Service light flashing-
40-ec means your freezer is running too much and can not get cold. You should call for service asap.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
  • 256 Answers
SOURCE: my sub z shows a
Check your owner's manual for a guide to the code. If not available, you may want to contact an appliance service company. It sounds like there is an issue with the "electronic control board" itself, but confirm this with a service company if unavailable in your manual.
Posted on Feb 17, 2010
SOURCE: sub zero ref 690 s model with error code ec 50
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
Posted on Jun 23, 2010
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero ref 690 s model with error code ec 50 what is that
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 632S error code 21
EC 21 has nothing to do with the refigerator. From the 600-2 series service manual page 3-21 EC 21 is Defrost Overheat fault.
The defrost system is only in the freezer and on a completely seperate refrigeration system. Clear the EC by holding the bell key pad down until you here a tone this is going to be a minimum of 15 but can be as long as 30 depending on the generation of your appliance. The part that you will most likely need to replace is the defrost terminator which stops the defrost cycle. You may have also had a problem in the refrigeration section which did fix by yourself, good job.
Oct 22, 2008 | Sub-Zero 632 / S
Sub-zero 632 error code 24
clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
ALL APPLIANCE REPAIR L.L.C
HOT SPRINGS
Feb 28, 2008 | Sub-Zero 632 / S
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Refrigerators Logo
235 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
