Question about Jensen VM9510 Car DVD Player
Bypass the parking brake on the vm9022
How do you bypass the parking brake on the vm9022
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
Press setup on remote control.
After enterning the setup screen:
1) Select the "Language" tab
2) Once in the language selection menu, press: 543210.
3) A menu "secret" screen will appear, select the "Hammer and Screwdriver" button
4) Select "Brake Override"
5) Select "On"
6) Press "Setup" on the remote again to exit screen.
WOALA!!!!
Posted on Sep 03, 2008
Jensen car stereo VM9022 has a password Need to bypass it
call Jensen at 1800-323-4815 they will give you the code
Mar 14, 2010 | Jensen Car Audio & Video
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
How do i bypass parking brake so i can watch movies
There is a parking brake switch lead that goes to the unit. You need to permanently ground it to bypass the safety feature.
Apr 28, 2009 | Car Audio & Video
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
forum.ecoustics.com/bbs/messages/4/338612.html
Jul 31, 2008 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
Pls try with the use of the remote control:
  • Press "Setup"
  • Press "Language"
  • Press 5, 4, 3, 2, 1, 0
  • Press the Tools icon (hammer/screwdriver)
  • Press "Brake Override" then press "On".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Car Audio & Video
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Parking Brake Bypass
I know my PLTS75 when we hooked it up. you connect the brake wire to the negative pole to bypass that
Mar 28, 2008 | Pyle PLDF7IN Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
868 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
