FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Advantium oven # SCB2000/2001 F3
posted by marshallc on Jul 16, 2008
Advantium oven # SCB2000/2001 F3 beeping (replace touch pad) - How?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 19, 2008
Not Rated (0)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2612 votes
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved in standard models.
Here are specific details on your model:
To replace the control panel, you will need to remove the microwave from the installation. You will also have to remove the top access panel.
Before removing the microwave from installation, disconnect all electrical power to the oven by turning off the appropriate electrical breaker.
Here are the steps for removing the control panel:
1. Remove the oven from the cabinet or wall opening.
* CAUTION: Do not use the oven handle to lift or lower the oven. Damage will occur.
* Be careful that electrical conduit is not caught or stressed during removal.
* This step requires 2 people for removal. The microwave should be grasped from the bottom and the front and rear of each side during removal.
* Remove the 4 mounting screws located in the front oven frame.
* Carefully slide the oven forward and out.
* Lower the oven onto a protective surface for servicing.
2. Remove the top access panel. There should be 9 screw attaching the top panel.
3. Disconnect all connector plugs on the control panel. CAUTION: Be sure to note the location and routing of wires for proper reinstallation purposes.
4. Lift the control panel to disengage the lower hinge tabs from the chassis.
5. Remove the control panel.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Advantium 120 900 Watts Convection / Microwave Oven GE JVM1750SMSS 1000 Watts Microwave Oven GE JVM1650SH Stainless Steel 1000 Watts Microwave Oven GE JES636WK 700 Watts Microwave Oven GE JES1851 1100 Watts Microwave Oven GE JEM25 800 Watts Microwave Oven GE JEM31 800 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Panasonic NN-SN657S Stainless Steel 1300...
f-82 flashing
kepps flashing f-82 panasonic... Answer This...
Whirlpool MH1170XS 1000 Watts Microwave Oven
Whirlpool microwave MH1170xsy0...
Microwave does not heat. Turn... Answer This...
Emerson MW8108P 1100 Watts Microwave Oven
MW 8115 SS Turntable doesn't...
My MW 8115SS Microwave's turn... Answer This...
GE General Electric Advantium SCB1000M 975...
electrical odor
Have an Advantium Oven... Answer This...
Microwave Ovens
I'm trying to find a
I'm trying to find a phone... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
