Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Convergence Hello, I turn on tv and I see the three diferent colors and three pictures what could be the cause and about how much to fix, can I replace the component myself, I'm good with tools. thank you. JJ my email is ayoelchico@sbcglobal.net
  • 1 more comment
  • ayoelchico Jul 24, 2008
    do you have the schematics for this tv.HC-P4752W 47 in. Rear Projection HDTV-Ready convergence IC's replacement
    thank you for your time and attention.
    JJ
    Thanx, i will try today and get back to you,
    thank you for your anticipated attention.
    JJ
  • Bruce Sebring Sep 01, 2008
    I have a Samsung HC-P4752W Rear projection TV, and I'm haing a convergence problem on the right side of the screen only.the red is almost 1/2" higher than the rest of the colors on the right side. Is this something that can be adjusted, or do I need to do an IC replacement? What are the part numbers I would need?
  • 4,234 Answers
This is a problem with the convergence circuit. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. FIgure on $25 each for the ICs.
Dan
Posted on Jul 16, 2008
  • ABRsvcs Jul 24, 2008
    Schematics should not be requied for this effort. Post the exact STK and I'll give you the pins that would heva either the fuses or low values resistors. Either component will be marked so replacing them should be relatively easy. Make sure that you use plenty of heat sink compound between the STKs and the heat sink too.
    I you found this information helpful, please rate it as such as that is the only way we get feedback on our efforts.
    Thanks,
    Dan
MY TV I CAN SEE THREE IN ONE
Tv have a problems known as a convergence picture problems,it is dead.Tv have problems like any colors lines R,G,B mis alignments,tv have like colors shadows pictures or a 3D pictures look alike?Yes,than the tv convergence board it is dead to causes these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 29, 2011 | RCA R56WH76 Projection Television
My tv works it looks Like the picture is three inches to the right. It has a right shadow.
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead to causes this problems.The tv convergence board must have be fixed.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 24, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
It has color at the bottom of the screen almost halfway up. I need to know how much to fix.
Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures?Yes?Mean ur tv have a dead convergence board to causes this problems known as a tv convergence picture problems.The tv convergence board must have to be fixed like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 06, 2011 | Pioneer SD-P50A5-K 50" Rear Projection...
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
If looking directly into screen you see all three lights Red Green Blue next to each other illuminating parts of the screen that color.
U mean on tv screen colors lines R,G,B colors are all mixed up and mis alignments all those R,G,B colors lines on the tv screen?Yes,u have colors shadow picture or 3D picture look alike?Yes,ur tv have a problems known as a convergence problems,it is dead.This tv convergence board it is dead must require replacing 2 STK of convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv picture convergence problems.The shop will cost u like $300-350 for parts and labors.
Jun 22, 2011 | Panasonic PT-52DL52 52" Rear Projection...
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
I cant line the red and green crosses up left and right but i can move them up and down. I have two pics in diferent colors
The tv have a convergence problems,it is dead.Tv have colors lines like R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
May 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture is going into a three d color
Ur tv have a problems known a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board is dead.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 43FDX15B 43" Rear Projection...
The three colors are separated and will not show as one picture I hard a pop before this happened but all three bulbs look like they are working
The tv now have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix the convergence board to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Jan 17, 2011 | Hitachi Televison & Video
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
cce772000
Level 1 Expert
