Question about Ovens
Ge model GRSR3920ZSS electric stove
Bright flesh and a small smoke in the oven during baking.
Now the oven element doesn't work.
Is it possible the fuse has to be replace? If so which one ? I see two 15 amps fuses on top are ther other ones for the oven?
Thanks
e-mail b2003k@hotmail.com
3 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Oven not working in Bake setting
Visually inspect the element for any kind of rupture on the shield covering the element. If it looks good the next step is the wire connections at the back of the element. Most likely is has a burnt wire.You will have to pull the back cover off to check this.
Posted on Nov 04, 2007
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Lower Oven Element
Are there fuses in this stove. There usually are in most electric stoves Quite often in the back behind the clock if there is one..
You may have blown a fuse.
Oct 18, 2017 | Frigidaire GLEB30S9F Electric Single Oven
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Apr 20, 2009 | GE JKS05 Electric Single Oven
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE Stove:
The symptoms suggest that the control relay has welded contacts. This was a result of the element failure producing a surge of current. You will need to replace the electronic control. Another possibility is to contact the folks at www.cgiltd.com.
They offer a repair service.
Jan 22, 2008 | GE Profile JTP18 Electric Single Oven
My ge spectra stove bake element is not heating
Dec 18, 2007 | GE JKP20 Electric Single Oven
Ovens Logo
167 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
