Insp12525 Thank for advise. Could please tell me what setting chaged in BIOS for hdd.? Suhasu
  • 107 Answers
When you go into the bois click hard drive there are two setting switch them and i will say you need to do something else first (Turn off cache to the hard drive) then come back and change it i think its AHCI/Sata
Posted on Jul 16, 2008
How do I remove windows 8.1 and replace with windows 7?
Go to BIOS settings by pressing either
F2 , F10, OR DEL on your keyboard as soon as its powered on.
Go to boot option - chage the hdd settings from UEFI
Dec 07, 2014 | Toshiba Computers & Internet
Unable to use S-ATA on Asus P5LD2-VM
in the BIOS set the SATA controller to IDE this should fix the problem. And try with AHCI selected.
Apr 16, 2013 | ASUS P5LD2-VM Motherboard
Hdd password pops up and hasn't been setup to ask for it. After trying several words it pops up Hdd error {06801]
Thank you for contacting Fixya. This is Anil.
I understand that whenever you turn ON the computer it pops for HDD password.
It appears that someone has set an HDD password on your computer. Inorder to reset it please follow the steps mentioned below:
If you have forgot BIOS/HDD password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
Jul 30, 2010 | Acer Aspire 5100 Notebook
Hello
As i search about what you need to know about the 500GB SATA HDD can support in MOBO, i say YES!
865GBF Desktop Board
Two Serial ATA connectors
If there any question just add comments.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 18, 2009 | Intel D865GBF Motherboard
Cant boot
In your bios you should be able to change your settings for the hdd. Make sure everything in bios matches your hdd & then save changes & reboot. Hopefully that will allow you to enter windows.
Jan 24, 2009 | Computers & Internet
BIOS doesn't find SATA HDD
Hi fallacy,
If you have the system disks and you can boot from CD, I would just follow the prompts to reload the operating system. If the computer cannot see the CD or HardDrive you need to reset the BIOS setting to factory default settings and that should restore the drives to be used. Note: Hard Drive should be Primary Master and CD-Rom, (not DVD-Rom if you have one) should be Secondary Master. If you have a DVD Rom drive I recommend unplugging both power and data cords from it and making sure the CD-ROM is set to Secondary Master, NOT Secondary Slave.
This should allow you to boot to a CD and reload the operating system. Unfortunately your files are lost.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 18, 2008 | HP Compaq d530 PC Desktop
I installed an additional hard drive in my laptop. The computer will no longer boot up. I've read the the BIOS needs to be changed by I don't know how.
Please tell me which Motherboard your system has???
If you have added an additional drive, check whether you have set the jumpers right for master/slave/cable select configuration.
If you bios setup to boot up from first HDD, then the bootable HDD shall be in master mode. Configure bootable HDD as master & additional one as slave.
If still no luck, Put this additional HDD on other IDE slot.
Tell me if this works...
Jun 21, 2008 | Computers & Internet
Same problem
You didn't tell what happen to your HDD after you set the jumper?...what to your HDD?..is it not detect?..Have you tried to change your IDE CABLE, instead changing the jumper settings to you HDD?..
Feb 25, 2008 | Intel D865GBF Motherboard
Hard drive
Have you gone into the BIOS to see if the IDE drive is recognized? If not, you may need to alter a BIOS setting to tell the system you'll be using both SATA and IDE drives. If the drive does appear in the BIOS then it may be a Windows setting that's causing the problem.
Let us know.
Dec 09, 2007 | Acer APFV MT (APFVUP5152) PC Desktop
Hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Nov 05, 2007 | HP OmniBook XE3 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
