Question about Intel D845GVSR Motherboard
Whether Intel D845GVSR Board support a 1GB DDR RAM with 400MHz Speed?
  • Anonymous Jan 13, 2009
    I have an 845GVSR mother board and two DDR 1GB 400MHz RAM. Sometimes the system will not boot, but sometime it will boot. How to solve this
    President:
  • 2,351 Answers
Hi job,
No the Intel D845GVSR does not support 400MHz memory.
Please go to this link & download the manual (At the bottom of the page) for you're board.
Go to page 14 in the manual for memory speed supported. While at this Intel link, suggest you add this to you're favorites.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Single channel DDR 333MHz is the highest speed supported.
It also depends which CPU you are using.
Good Luck!
You'll understand once you read pg. 14 in the manual.
Mike
Posted on Jul 16, 2008
  • 1,031 Answers
Yes your mainboard can support 1GB ram400mhz without any issues.check your board manual However if any issue arise you can upgrade the bios
Hope you find this information helpful.
2 Suggested Answers
  • 93 Answers
SOURCE: Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Posted on Jul 25, 2008
Testimonial: "Thank you very much"
I have 4 slots of ram in intel d915glvg how much ram can be increased in each slot
Good Day.
Your motherboard can accommodate up to 4GB of memory. That means you can have 4pcs of 1GB DDR SDRAM 400mhz or 333mhz memory modules to maximize your memory. Just be sure to have the same speed (400mhz or 333mhz).
Just let me know if you need some more help.
Good luck,
Tedmac
Sep 25, 2010 | Intel D915GLVG Motherboard
Does intel d845gvs1 motherboard supports DDR2 ram?
From an Intel page of this boards nearest "relatives" in the d845 series...
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008824.htm
It shows the following for memory speed options:
333, 266 and 200 MHz DDR SDRAM
And if I remember correctly, that era of motherboards came out when ddr2 didn't exist in the market. Beyond that, the above stated memory speeds show that this board didn't even support the PC-3200(400MHz) ram, which was the final step in DDR1 memory.
The short answer to your question is: No, that motherboard of yours does not support ddr2 ram.
I hope that gets you the information you need.
Mar 12, 2010 | Intel Motherboard
My desktop has intel 845gvsr board, n have a 256 mb ram installed on it. i want to upgrade it to 1gb what kind of ram should i go for
Each memory slot can hold DDR PC2700 or DDR PC3200 Non-ECC, Non-buffered RAM with a maximum of 1GB per slot.
You can refer to this site for more info on your RAM and motherboard.
http://www.crucial.com/store/listparts.aspx?model=D845GVSR
Thanks for using Fixya.
Feb 23, 2010 | Intel D845GVSR Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Does D845GVSR supports DDR 400 MHz RAM?
unfortunetly your motherboard supports only 200, 266, and 333 MHZ
Nov 29, 2008 | Intel D845GVSR Motherboard
Jul 25, 2008 | Intel D845GVSR Motherboard
Regarding upgrading RAM
You'll need 184-pin ddr sdram memory
Supported speeds are 333, 266, and 200 mhz
Max memory for your motherboard is 2 gb, so the best you can get for your motherboard is:
2 x 1GB 333mhz 184-pin DDR SDRAM
May 21, 2008 | Intel D845GVSR Motherboard
Regarding Upgradation of Rams in My mother board
Please don't post your question twice, I've already answered your other post of this problem
Can i use DDR2 RAM in intel 865GBF motherboard?
NO ! you can only use DDR 1 ram (266Mhz,333Mhz,400Mhz) speeds only
Mar 30, 2008 | Intel D865GBF Motherboard
Intel D845GVSR Motherboard Logo
700 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
